1 - 8 of 8 Posts
I've never seen rotors with titanium coated hats before. Does anyone know who makes these?
** The Enforcer **
I don't know that titanium rotor hats would be any better than aluminum. If they were I'd think the major manufacturers would already have them as an option. Don't get me wrong, I'm a big fan of titanium when used properly. Any material has pros and cons.
San
German Reimport
Those are EBC turbo groove discs and they are simply zinc plated, not titanium.
By titanium he means titanium nitride coating, which, as correctly identified, they are not-
they are the ones pictured, the EBC rotors, and the coating is a zinc yellow dichromate coating- the rotors are first zinc coated and then yellow chromate conversion coated.
Titanium nitride coatings are used as a surface hardening and protection for sliding surfaces as well as corrosion resistance. It is very thin and expensive.
yellow dichromate zinc coating is a corrosion inhibitor and better suited for rotors, yet still a more expensive (and maybe unnecessary) option for rotors which are usually just zinc plated.
** The Enforcer **
Commonly used on drill bits, right?
San
German Reimport
San
Titanium nitride yes.
Zinc coating and yellow chromating not so much.
That is a surface coating for corrosion protection often found on bolts, brackets and such.
I wonder if the coating on the EBC rotors is ChromeVI free....
Discussion Starter · #8 ·
Thanks guys. They had just caught my eye and I was curious. I'm on the OEM's right now at the 26mm spec so no need to change for a little while.
1 - 8 of 8 Posts
