Thanks. Is there any way to know how much additional torque and power this particular unit might make? As I understand it the MP62 is much preferred over the MP45. Any issues I should understand about this unit?MP62. Might be a BWR kit.
Thanks Kevin, you in good company - I emailed those same photos to Fred at BWR and he also concurred that it was the Katana kit, and it would be putting out about 200-210 to the wheels (235 to 245 crank horsepower). I then compared some photos of the Katana kit which seems to confirm Fred's assessment.This looks like the Katana Kit. This is a MP62 kit. If everything is factory, BOE sells a tune for these that is around 250 Crank hp. With an older tune probably slightly less than that.
this is great information. Thank you. I’m walking away as the seller is not negotiable on price and the car is not worth what he thinks it is worth. I’ve found that many sellers think the appreciation of these cars in the last 2 years is going to continue indefinitely. Many people don’t understand the current market.I have the katana kit on my car and had to rebuild the super charger at 40k miles (resurface impellers) because a low quality air filter was fitted to the car. It was a high flow type foam filter but it did not seal properly at the edges and allowed debris into the intake. I would suggest verifying there is a paper type filter fitted to the car you are buying if you want to avoid this issue.
Also you should probably verify the fuel pump has been upgraded or replaced at some point. The katana kit came with upsized injectors that will stain the stock fuel pump, mine is about to need replacement.
He was asking $60k. The car had less than 10k miles but no service records, and the carfax suggested the car hadn't been serviced in 8 years. Nice car, not perfect (drilled front bumper for license plate, some oldschool chin protectors drilled into the bottom of the clamshell, etc. Would sell in the mid 50's I think.Curious how much he was asking for. Clean title and low miles go for ~$50k.
Given these cars are 3rd or 4th cars for many, market conditions don't impact this car segment as much as you would think; while it might have a Toyota engine, you aren't buying a Celica. shrug
