1 - 7 of 7 Posts
For those who have painted any part of the top dash what type of paint was used?
On a different car when I painted the dash I used adhesion promotor and regular base/clear paint.
My dash and all other interior plastic surfaces are painted piano black. Any automotive paint will work, but that is not the trick. Prep is everything. These plastic surfaces were not made to be painted. The plastic is contaminated with mold release compound, which will prevent proper adhesion. You'll need to clean the surface with a strong solvent. The surface should be sanded to eliminate any sheen. Then prime it with a plastic primer. I also suggest adding a flex compound to the paint (like is used to paint plastic bumpers).
Although the concept is simple, execution is tricky. If you don't get the mold release cleaned from every surface irregularity, the paint will shrink and crack--very ugly and even harder to repaint. Convex angles, such as where your air vents transition to the dash surface are hard to address. You might want to start with something easy like the door sills, then the console and finally the more complex dash parts. Wait for the paint to cure (weeks) on the first couple of parts to evaluate how you did, before you start with more complex parts.
Good luck. My painted dash looks great.
Please post pics!
1 - 7 of 7 Posts
