10 is rich. 14.7 is stoichiometric.I have read that you don't want a supercharged motor to run lean, but what does that really mean? I have a wideband in my car and run about 10 at WOT, is that rich or lean? Does this ideal number vary from engine to engine?
The air filter has nothing to do with the air/fuel ratio...just the quantity of air going through the intake tract.Interesting..... thanks for the responses! I just installed a cup air box, maybe that will get me closer to ideal without a tune for now. Have not even driven the car yet with the new inlet so I will keep an eye on it.
It doesn't work that way. Stoich is not where best power is made. It never has been in any combustion chamber. All sorts of good books have been written on this and they dedicate chapters to explaining why this is the case. It's not just a single sentence to explain.I'm starting a philosophical discussion now; If you need to be that rich (12:1) then my guess would be that the combustion chamber is a very poor design in this engine... What other reasons would the mixture not mix? The other potential design problem would be ignition...the spark plug is not in an ideal spot... again poor combustion chamber design. Anybody else have any thoughts or ideas?
Phil, is there a piston that is better for mixture that you have noticed?
Philosophically... is it related to mixing?I'm starting a philosophical discussion now; If you need to be that rich (12:1) then my guess would be that the combustion chamber is a very poor design in this engine... What other reasons would the mixture not mix? The other potential design problem would be ignition...the spark plug is not in an ideal spot... again poor combustion chamber design. Anybody else have any thoughts or ideas?
Essentially, 14.7:1 is the mixture under ideal conditions. Pure fuel, pure air, complete combustion products. None of these things happen. Neither the fuel nor air are pure, the fuel does not completely evaporate into the air before combustion, the combustion does not have time to complete, not all the fuel burns, and temperature issues cause chemical formation that isn't considered in the 14.7:1 formula. So you have to run rich to make the most of a real world situation. The rich mixture maximizes the air that's combusted and helps to keep the engine cooler.I'm starting a philosophical discussion now; If you need to be that rich (12:1) then my guess would be that the combustion chamber is a very poor design in this engine... What other reasons would the mixture not mix? The other potential design problem would be ignition...the spark plug is not in an ideal spot... again poor combustion chamber design. Anybody else have any thoughts or ideas?
Yes, partially.Philosophically... is it related to mixing?
OK...so what can the University of Wisconsin do to improve on the efficiency of the 2ZZ-GE engine? I'd contribute to that cause...Essentially, 14.7:1 is the mixture under ideal conditions. Pure fuel, pure air, complete combustion products. None of these things happen. Neither the fuel nor air are pure, the fuel does not completely evaporate into the air before combustion, the combustion does not have time to complete, not all the fuel burns, and temperature issues cause chemical formation that isn't considered in the 14.7:1 formula. So you have to run rich to make the most of a real world situation. The rich mixture maximizes the air that's combusted and helps to keep the engine cooler.
University of Wisconsin - Small Engine Research Center '00![]()
A lean mixture also helps keep the engine cooler.Essentially, 14.7:1 is the mixture under ideal conditions. Pure fuel, pure air, complete combustion products. None of these things happen. Neither the fuel nor air are pure, the fuel does not completely evaporate into the air before combustion, the combustion does not have time to complete, not all the fuel burns, and temperature issues cause chemical formation that isn't considered in the 14.7:1 formula. So you have to run rich to make the most of a real world situation. The rich mixture maximizes the air that's combusted and helps to keep the engine cooler.
This all depends on your definition of efficient.the 2zz is already quite efficient as far as production motors go. It makes 100hp/L or better. Not many production motors do that even today. How does one complain about that?
Of course better intake, exhaust and head porting will make it more efficient. You're welcome to implement those features as many of us do. The head is quite good right out of the box, as evidence by greater than 100hp/L. All that said, making the motor a more efficient pump, it will still take about 13:1 in NA form and about 12:1 in FI form to make best power on pump gas (again, there are ranges here)...
Phil
But the OP dd not want theory, only the number.To anyone that would like an introductory article on the basics of air-fuel mixtures, google "Pelican's Perch Mixture Magic". It's a well written, easy-to-read classic.
Do you have the stock tune? As others have noted, 10 is awfully rich. Which A/F meter are you using. Many, such as the NGK, need to be calibrated when first installed. So the values you are seeing may not be accurate if it was not calibrated.I have a wideband in my car and run about 10 at WOT
