1 - 17 of 17 Posts
Well, I believe they are R compounds. I did some searching the other day, and came to the conclusion that the A048 is in the same line as the A032. So it should be a relatively long lasting R compound. The A032R is listed with a 60 treadwear rating.
A lot of the guys in the UK run their 7s on Avon ACB-10s which have a tread wear rating of, and I am getting this off my set of ACB-10s, 20! They report 3 - 5000 miles, it all depends on how you drive and the weight of the car. The obvious answer is a set of daily road wheels with tires that have a tread wear rating of 100+ and your fun tires. I have three sets of wheels for my Seven, ACB-10s for dry track, Avon CR-500 for damp track and autocross, again tread wear rating of 20. And Avon ZV1s with a tread wear of 300, for the street.
I for one wish the Yokos on the Elise were a little sticker!!
Forum Mop
Discussion Starter · #8 ·
60 isn't terribly bad ... the RA-1's that i use are ... if i remember right .... 40. And I get quite a bit of roadcourse mileage out of one set.
60 won't be too bad on the street. After that, I'll buy another set of RA-1's, and leave 'em at full tread depth. :)
I also use RA1s for street tires and expect the LSS tires to be about the same.
Speaking of extra wheels/tires...
I've been wondering if anyone knows if an Elise can be ordered with an extra set of wheels and how much it would be? Are people who are planning on having extra wheels planning on using Lotus supplied wheels or some aftermarket wheels?
Forum Mop
Discussion Starter · #11 ·
unshaved, i'm assuming?
what are your experiences with 'em as a daily tire?
How many miles are you getting on them?
Forum Mop
Discussion Starter · #12 ·
I'd assume that Lotus-purchased wheels would be pretty pricey... If I were thinking about a 2nd set of wheels, i'd look into something from HRE or Fikse or something.
For street tires I get them unshaved. FedEx showed up an hour ago with another RA1! The delivery people always seem amused I get tires delivered to my house.
I think I get about 10,000 miles on a set of RA1s. But they are sticky miles. I love the confidence I have with these tires. When they get too much wear on one edge (from camber or toe settings), I flip them.
Regarding an extra set of rims.. I am not sure. I don't want to order them as parts from Lotus. The cost of the Elise will be high enough. :eek:
I am choosing to ignore the issue for now. When the car gets here, I will investigate aftermarket rims... but I am mainly hoping someone else that buys an Elise will take off the stock rims and replace them. Then I can get them from that person. I hope.
Forum Mop
Discussion Starter · #15 ·
NICE. I used to LOVE driving home from the track with my R's still mounted. i'd go home & drop my other tires off, then head out through the streets to have a little fun. :D
What do you mean by "sticky miles"?
I can handle 10k on a set of tires, no problem.
Miles with a lot of grip. IMO, grip is more important than treadlife for safety reasons. And I enjoy the freeway cloverleafs. :)
That's what I did with the Spyder and it worked out. The only sticking point with the Elise might be its limited numbers. Time to go surf some Euro Elise boards and see what they do for extra wheels...
1 - 17 of 17 Posts
