1 - 8 of 8 Posts
I was checking out underneat the front of my car to see where water could be getting into the drivers side footwell and I spotted this little tube coming out of the passenger side. Looks like a drain for the heater/ac unit, but does anyone know what it's for?
Also, is the flat vertical section behind the suspension directly infront of the footwells?
Luke
I noticed 2 black rubber tubes (not articulated like yours) on both sides of the car in around the same location as the one pictured in your thread. I always figured it was the drains for the engine lid.
I once owned a miata and the frame filled with water causing a big sloshing sound when ever I hit the brakes or accelerated. Turns out the drain tubes from where the softop met the body were plugged with a build up of leaves and other debris. Once I cleaned it out the problem went away. Maybe you have a similar problem with your Liz.
That's because that's what it is. The corrugated tube (looks like the kind that wiring goes into) is the AC drain.
Just realized the picture of your tube is at the front of the car. The tubes I spoke of are in the rear, probably drains for the boot lid.
I'll answer my own question. This tube connects to the AC unit, and goes through the arch in the plastic piece nearest the cabin.
I had pulled this out when replacing my resistor pack, and was able to put it back in with a helper, my iPhone (to check position under the A-arm pivot), and a long flexible grabber.
To replace tube:
1) With AC unit removed, push the end of the tube without rubber coupler through the arch, you will feel it hit the back of the extrusion to which the A-arm pivot connects. At this point, push the tube toward the passenger side.
2) Check that the tube is underneath the A-arm pivot, if yes proceed. If not, pull it back through the arch, and try again.
3) Have a helper hold the tube, so you don't pull it through the arch. Use a grabber to grab the end of the tube, and pull it into position.
4) Temporarily tape the tube in place near the A-arm pivot, to avoid pulling it back out.
5) With AC unit partially in place, connect tube to the bottom of the AC unit. There is a hole where it attaches, and a rubber plug on the other side.
1 - 8 of 8 Posts
