Wheel Bearing Replacement
4622 6
Has anyone successfully changed the front (or rear) wheel bearings on their Elise?
I'm having a tough time getting the hub out of the bearing. I have to do this before I can get the bearing out of the ally bearing mounting block.
I've tried soaking the bearing & hub in silicone penetrator for a couple of days and then using a pillar drill (just the vertical rack) to try to push the hub through the bearing, but it won't budge.
Is the best approach a hydraulic press, or a good whack from a hammer, or something else?
I don't want to damage either the hub or the bearing block. The bearing is toast either way.
Also, when fitting a new bearing, is it a good idea to grease the mounting block beforehand to prevent the bearing corroding in the block or the hub in the bearing?
Thanks!
1 - 7 of 7 Posts
Hi, Robert !
The bearings of the Elise are all the same (by Timken) but there are different hubs.
I Think up to 1999 Elises had all Ally hubs, after that the rear hubs have been changed to steel hubs. With the new Mk2 (Federal Elise or whatever you call it) I don`t actually now.
A hammer should better not be used with the Ally hubs, a hydraulic press with a selfmade stamp (?) would be best.
In a german board was a thread about parts of the topic: http://www.elise-forum.com/view.asp?catID=1&forumID=20&topicID=14034&sessionID={3F0EFBEA-8EBB-4050-AEAB-71A71594239E} , but it's in german.
Befor pressing out the old bearings make sure that the two circlips are out, they fix the bearing in the hub and they only fit in when the bearing is mounted correctly.
Some did bearing changes with an oven and a fridge....
to insert the new bearing put the hub in the oven and the bearing in the fridge, after a day in the fridge the bearing should fit without problems into the hub after some 60 min at 200°C in the oven.
To get out the old bearing put the hole thing into the oven but remove the circlips before and after taking it out try to cool down the bearing pretty fast (with sports spry or dry ice fe).
Hope that helps a bit.
For more detailed information please contact: [email protected] , he did this a few days ago with his Elises.
Matthias
two distint issues here...
1) - getting the flange out of the bearing - this is a press job, should not take too much load if doen right, but a 5 tonne press is essential.
2) - getting the bearing out of the upright, with the Ali uprights, heat them to ~200C first, then it's way easyer to push it out, same goes for re-fitting, replace on the the C clips, then heat the upright, then drop the bearing in, normally they will fall in, somethings a rubber mallet is needed just to make sure.
the steel uprights on latter cars (S1) just requite brute force with a press, heating helps, but not to the same extent as ali (different expansion rates)
1 - 7 of 7 Posts
