1 - 6 of 6 Posts
Hey guys, so when I make turns I hear this rattling or clicking sound in my rear right wheel, it sounds like there's a loose screw or something.
Anyone else have this issue?
Administrator
Not sure if Evora is same as Elise but I had clicking noise from my right front wheel and after numerous fix attempts I found anti rattle tape was applied to one side of the calipers but aftermarket pads are slightly smaller so a second piece of tape was used on opposite side of calipers and the sound went away. Here's my link to that fix.....https://www.lotustalk.com/forums/f3/finally-got-rid-clicking-rattling-thumping-465176/
Loves to talk
Rather than direct people towards the existing discussion, there's this:
Check your wheel bolt torque settings. But it's more likely you require the new style bolts which completely solved the problem for me. If you have the old style bolts, the problem may very likely return at some point. It's worth checking out if you haven't already.
1 - 6 of 6 Posts
