Hi guys I'm back. I've been looking at several wheel spacer manufacturers and there are several things to check before I can order the right spacers for the Elise. They are asking me for Center Bore size (67.1, 54.1, etc.) does anyone know the Bore size for a 2005 Elise or how to measure it? and can someone please translate for me the following fine print about cut-outs etc. the info comes from a Miata application since they use 4X100 wheel pattern. I want to make sure I purchase the right spacers,Thanks.
Note:
S9) Spacers can only be used with wheels that have cut-outs (facing the hub) to clear the stock studs. Please check as follows: original stud length (i.e. 35 mm) minus spacer thickness (i.e. 25 mm) = 10 mm excess stud length. The cut-out should have a depth of 11 mm.
S11) The centering of the wheel is only possible with the wheel bolts! Therefore, it may be necessary to do wheel balancing on the car - to avoid possible vibration.
S16) Mazdas have various wheel studs that are dependant on the model, axle or year manufactured. Before ordering, please check the knurl diameter of the original wheel studs on both axles. In the Eibach kit, it will include wheel studs with a knurl diameter.
S33) Original studs must be changed. Longer studs are included.
