1 - 4 of 4 Posts
Got all set up to read OBD2 only not to be able to identify the pass front port nor the rear port.
Only port I found up front on pass side was a port that appeared when I disconnected it from what appeared to be a plastic holder right in front of the pass knees. However, that connector to not match my USB cable ELM 327 interface.
In the rear, didn't want to fish around to hard to find the port. Any pics of what the font and rear ports look like?
Mark
if V8 - near the battery location - look up near the relay & fuse box -- it's right there, I can see it now!!!
At the passenger side, look under the dash -- it's there, I can see it now too!!!
If you can't see it --- tough luck!
they are the same..
as stated the port is under the passenger dash area
and the rear is tucked under the battery next to the fuse box in the boot
OBD Ports
Right! Found the rear port. Readings using Peter's Lotus V8 software looked pretty good. One code P0411 that cleared.
Should all of the options on the reset page of Peter's software be selected if I plan on retraining the system (battery as been disconnected for quite a while at this juncture so may need to do it anyway...is this correct)?
mark
1 - 4 of 4 Posts
