1 - 5 of 5 Posts
I have no cold start components working, my manual says they run off the low oil temp sender, where is that on an 88? I thought they run off the high temp coolant switch.
Thanks alot, I completely forgot that was under there, I only remember the pressure sender when I had my intake removed in the past. I have been disturbing that area of the motor alot lately, I probably messed up the wiring to it or the connectors. I was tearing into the wiring to all the above the engine cold start devices looking for faults and two of them had old crusty broken, I mean completely broken off wires, I was sure one of them was it NOT. But I just went thru a mess with my dist. timing recently (very recently) and im sure I created this problem myself, but at least I found the others too, at least now my cold start injector will work, it couldnt of been before, that and the warm up reg. heater. What a mess, if there was a dumpster big enuf nearby, I be tempted to build a ramp and drive this car into it.
1 - 5 of 5 Posts
