1 - 8 of 8 Posts
Where is the rev limiter in first gear when in sport mode? I thought it was at 7200 rpm, but my car seems to be at 6900 rpm, it only has 1200 miles on it.
So I was wondering if Lotus set it low until it was more broken in, or is my tach off? :shrug:
Fuel cuts out at close to or at 7000RPM in sports mode (as I've observed), however the peak rev limit appears to be 7200RPM.
I have videos to demonstrate peak revs with Sports mode on and off, if you want, I can upload them later.
If you could upload those videos I would really appreciate it.
Is it like an over rev feature that likes you hit 7,200 for 1 or 2 seconds?
Illegal Alien
I think it is engine inertia. My ECU dump shows a peak of 7209 rpm but my other 4 readings are 7009, 7023, 7067, 7088
I've noticed that I can get the revs higher under load while driving than just free revving FWIW...it seems to cut at about 7k when free revving and closer to 7200-7300 (tough to tell on the tach while driving) when pushing it on the road
1 - 8 of 8 Posts
