One day after I finally replaced my passenger switch, the window made a popping noise and struggled to come up. I left it as it was (up) and took it apart to investigate.
Turns out the tension spring must of come undone and the cable popped off resulting in the cable binding up. I put it all back together but it just does the same thing again. Is there a way to adjust the tension in the cable so that this doesn't happen again?
I would love to see a diagram of the window assembly if anyone has it so I can vision what I'm trying to do or if it's possible. It's bad enough fitting your arm back there trying to feel around.
Enjoy the pic, the cable on the left is the one popping off the bracket and if you look closely you can see where it was bound.
Thanks as always.
Thanks as always.
