Time for another winter mod, replacing the black plastic slat grills on the engine lid cover with an aluminum mesh, à la Exige.
Tools and Supplies Summary:
1. Mesh from www.Customcargrills.com. I chose the Stacking Oval XXL Mesh. One sheet was enough to do the whole lid, with some left over. Maybe enough to do the side intakes, but not another lid.
2. Krylon Camouflage Ultra-Flat Black paint. Nice Matte finish, about 4-6 coats per piece of mesh.
3. Double-sided foam tape to hold mesh to underside of lid.
4. Rubber Mastic Tape to secure grill to lid. I made a "sandwich" of double-sided foam tape, mesh grill and mastic tape. Very solid construction and waterproof.
5. Hole Plugs, nylon locking to conceal/hide slat mounting holes on lid. I spray-painted the plugs black to blend in to the lid.
I made a template for each opening, cut out the wire mesh with Dremel, painted mesh, applied tape as needed, attached mesh, fitted plugs to lid holes (20 holes in all!!).
Pictures show installation process and final look.
If nothing else, I saved some weight!!:coolnana:
Regards,
Wayne
Regards,
Wayne
