1 - 5 of 5 Posts
Hi, Guys:
Here is very inconvenient with 4points in a CF seat.
So this is an idea: adding a addtional power window switch on shifter console.
Any guys know where and which wire is the power windows locate?
Hi, Guys:
It could be done but 2 wires from each window would have to be routed into the door.
Michael
There is a way to do it without routing new wires into the door. This will involve disconnecting the wiring from the existing door mounted window switches and making a few connections. This also presumes you can access the wiring in the car after is passes through the door. Two new DPDT switches would be used.
Michael
1 - 5 of 5 Posts
