1 - 20 of 33 Posts
2007 Lotus Elise Storm Titanium
Picked up a 2007 Elise just over a month ago. Already have done some things to the car (I understand this is personal taste) Headliner delete, carpet delete, sun visor delete, and replaced all the seat bolts with stainless steel. I also have a bunch of parts on order: rubber floor mats, aluminum floor mat buttons, carbon fiber wide side scoops, front splitter from Moto-build.com, new rear speakers, race mirrors, and ethos wheels 15/16 setup, and rock guards.
My question is what to do next.... should I continue down the path of cosmetic upgrades or are there mechanical things I should focus on preemptively?
Cosmetic: rear diffuser, exhaust (I consider this cosmetic since it doesn't increase performance all that much), mesh grill kit, etc.
Mechanical: replace toe links, install baffled oil pan, replace front radiator
Car has 16k miles on it and everything looks fine mechanically... where would you put your money? or would you do something different?
I will mostly drive this car as a daily driver with some spirited canyon driving 1x per month and a goal to eventually auto cross and then step up to some track driving.
Thanks for your opinions!
1293172
Why on gods earth would you replace the seat bolts with Stainless, unless you bought very special SS bolts. First off SS bolts are not as strong as the bolts that are already in there, and secondly, they are heavier. 😂
Reactions: LostPawn and TJBNJ
Good to know... I'll look into ordering stock bolts. The interior of my car was a little rough and I had rust on the seat bolts so I swapped them out.
And hopefully you used anti seize on the SS bolts so they don't gall when you remove them.
Reactions: StressCraxx
Toe links and radiator gets my votes. These things can fail even just on the street.
And add anti seize to prevent the gall as already stated.
Perhaps add to the list - upgrade to your headlights to HIDs.
Discussion Starter · #9 ·
Thanks. I was leaning towards the BOE links. I will also look into HIDs as well.
Administrator
Like you're plan and others said toe links and brace, radiator, shocks and inspect your bushings especially once you get into tracking. Plenty of threads on what to plan for and what you'll want to do for tracking. PO told me the two greatest improvements he experienced with the car was adding the Ohlinds and then the REV300.
2005 Elise LSS Saffron Yellow
BTW, always, always use antiseize on any ferrous fastener (steel or stainless) going into aluminum. Especially on parts of the car that get wet (like the interior of a convertible).
Discussion Starter · #12 ·
Yes. Thank you. I am actually going to do this tonight and moving forward.
Discussion Starter · #13 ·
I would love to do a supercharger.... maybe in a few years... that I would need to save up for.
1. These cars have large (i.e. dangerous) blind spots. Multivex mirrors are NLA, but RLS (Really Light Stuff) offers very good tape-on replacements. I
Sounds like this “excuse me”….
Get something such as a Stebel Nautilus. Or, from beloved parts supplier, RD Enterprises: Compact Air Horn $59
Ultra Compact two-tone air horn unit measures about 4-3/8" tall x 5" long x 3" wide and weighs under 2 lbs., and it's LOUD! The sound measured at 2 meters is 115 dB. Easy installation because there's only one part to install, horn compressor relay and instructions included.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s and InoKinetic’s for two examples.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club). Get help wherever you are, using the contact booklet they update every year. (I’ve helped a few ppl who contacted me.) This is who stages LOGs (Lotus Owner Gatherings) every year. https://lotusltd.com
Plus, “How to bleed brakes”:
Maintenance and Repairs.
How to Search:
no space between site: lotustalk.com
Addict
2007 Lotus Exige S
Seat Bolts - yes you need to replace the SS bolts with something stronger.
Toe Links - check to see if you already have a brace there or upgraded links first. If nothing has been done already you do need to upgrade here. I have the BOE links but they require drilling, it's easy enough but you also mentioned you are a rookie at mechanical items so consider this as there are some bolt on options as well. For me the real consideration with the BOE links is that if you plan to upgrade bushings later it'll make that more time consuming having to resize 2 bushings.
Seat Time - this is really the best upgrade out there. Get seat time either AutoX or on a track with an instructor. Once you know if this is a direction you want to go with this car then get more seat time and then start to upgrade the car. If street driving and canon carving is all you want to do the car really doesn't need anything aside from the toe links, good tires and suspension.
Those last three words of your post. That experience might well help you figure which way you want to go with this car. And your own life experience.
Just curious. Replaced seat bolts with stainless. Wondered why.
Discussion Starter · #17 ·
Thanks. I will check out my Toe Links this week and assess them. Seat time is on my list... I have done some track time with my 911 prior to owning this Lotus but the cars are completely different in how they drive. So getting some more experience in the Lotus and with an instructor is definitely on my list.
Discussion Starter · #18 ·
Yeah... I honestly thought the stainless were stronger and would not rust. Lesson learned there. I am going to remove those tonight. My stock bolts are still usable they just have some minor rust on the top and can suffice until I order OEM replacements.
Discussion Starter · #19 ·
5. Transmission:
And, use:
How to Search:
VERY helpful. Thank you.
Highly recommend the kit that braces from underneath the car. Syspak one version. Bolts don’t matter so much as that they are threaded into aluminium, relatively very soft. Even easy to cross thread.
Especially good to do if some serious driving is ahead. Even with harness properly secured to cage/chassis we want that seat to stay where it is.
1 - 20 of 33 Posts
