1 - 5 of 5 Posts
tried to jump start my battery today and got confused, connected the + to the - terminal. car idled well but when i ran the car even if ti is at 180+ temp car is cutting off at 6000 rpm. is it possible that i damage the ecu? pls. help! thanx
Is the check engine light on? Sometimes it takes three run cycles (starting and turning off the engine/ignition) to clear faults. Try that and see if it clears your problem. Connecting the jumper cables backward shouldn't hurt the ECU. Other stuff maybe, but not the ECU.
thank you so much drstvk. got it fix but needed to clear some codes that pop up.took me 3 times to cancel the 5 codes and yes the fuse was bad. thank you very much!
1 - 5 of 5 Posts
