1 - 7 of 7 Posts
Looking for a usable stock heat shield, I have only the U-bend but would like the full shield.
Also need the little rubber dingus that the gas access cover closes on. This is a little rubber part that fits into a small hole, and the gas access cover rests on it when closed. Mine is missing and the door does not sit flush.
I am in San Diego.
I lost the rubber stop also. A small stainless screw works well as a substitute and doesn't fall out as easily.
Keep an eye on the dielectric connection the corrosion will occur occasionally. It is more noticeable when you do not clean.
A wire tie works well for this too. When you zip it, make sure the head ends up where the rubber standoff would have been.
1 - 7 of 7 Posts
