1 - 9 of 9 Posts
German Reimport
After spending the afternoon with my multimeter in the trunk I finally figured out how to get amber turn signals as well as a rear fog light installed.
Therefore I need to replace my outer LED lights and install a second set of the inner ones instead (the ones with the reverse bulb in the center).
The rest is just some extra wiring and swapping pins in the connectors.
So if anyone has a set of the inner LED lights sitting around in the garage - I'd be very interested to purchase them.
I will then have the outer signals (including the ballasts) left over - so a trade would also work.
Thanks,
Steve
I have a pair of inner euro LEDs - I'm not sure that these would work for you, but they are available if you want them.
German Reimport
They would be absolutely PERFECT.
That way I can use my current inner ones as the new outer ones.
Do you know what the segments look like?
I assume they are pretty much the same as the US ones...(each with a 0.5Watt and 3.0Watt outer red ring and a center bulb).
How much are you asking?
I assume the center bulb fixture would come with them?
Thanks a bunch:clap:
Steve
German Reimport
I just read your sig:
4,100 miles - scraped hole in front clamshell
6,500 miles - garage door closed on rear clamshell
6,900 miles - AC failed
9,000 miles - front wheel arch liner fell out
9,950 miles - right inner tail lamp fell out
Is that the one ;)
shay2nak
subscribed
Is that the one ;)
:) No that was one of the original tail-lights and actually that was the excuse I used to upgrade to the LEDs in the first place.
shay2nak
FYI, the dealer sells each LED taillight for $258. I wanted to do your planned mod as well haven't had time to do it. So I hope you are successful.
German Reimport
Ordering them thru the dealer (Lotusgarage) is what I did now as well.
They should arrive today. Installation should be very simple, but unfortunately will have to wait since I'm currently busy fabricating radar detector mounts...;)
But I'll post the results once I get around to do the mod.
1 - 9 of 9 Posts
