Conforfoam or Backsaver is what Probax is called when it goes to outer space...
BACKSAVER FOAM from Aircraft Spruce
CONFOR FOAM SEAT CUSHION from Aircraft Spruce
OEM foam is injection moulded to shape but you can cut/shape your own from sheet foam no problem. Use different densities in layers Firm/med/soft in the right areas (under your butt esp). Google the 3M Conforfoam, you can get it in various thickness's & densities. For adjustable lumbar, get the inflatable OEM bladder part.Oh cool thanks for the links... I think the Lotus Probax foam has some kind of lumbar support in it, right? E.g. the foam isn't just flat but has a contour to fit your back, correct?
