1 - 20 of 20 Posts
Q
Guest
If anyone has removed their intercooler shroud (the plastic piece on the back that connects the roof duct tubing to the IC, I'd be interested in buying it from you.
This is the piece that is siliconed onto the backside of the I/C
Thanks,
Q
shay2nak
fyi, dealer price $150
Q
Guest
bump for used... I don't need new
It can even be cracked...
The duct is glued to the intercooler with Sikaflex, you will have no luck finding one that is usable.
Q
Guest
I need one for research purposes (to experiment with making a mold).
So it can be cracked, but for the most-part whole?
Does that help?
Are you making a mold for the other 11 RLS group buyers like myself who had no idea that procuring this piece was going to be necessary to install the new intercooler? I am glad I found out about this before I began the install.
You can remove the stock ABS - plastic shroud. It is a bit of a project, but many people reuse them. Use ABS two-part epoxy to fix the cracks that are likely to appear in the corners of the shroud.
Q
Guest
Discussion Starter #12
Yes and no... I am making a special mold for my own use, that could possibly be used by others if interested....
Q
Guest
Discussion Starter #13
bump...
still looking for cracked, used, removed I/C duct.
Q
Guest
Discussion Starter #16
Yeah, I need one I can f_ck up... not a nice carbon fiber one.
Q
Guest
Discussion Starter #20
Bite me.
I need one to make a mold from. So I don't need a new one.
1 - 20 of 20 Posts
