You will understand when you see them. Basically, the rails are designed to go right against the floor pan. I wanted less tilt back on the seat than they allow. The part you cut off is the angle you gain. It it is not cut off, those pieces would punch through the floor of the car. You end up with the bottom of the seat right against the floor.... you sit higher in some go karts.... Mini Coopers look like buses going by.
