1 - 5 of 5 Posts
Perhaps if you explain its application and uses you will elicit more interest. Most people wouldn't know this kit is for tilting the steering wheel up to make entrance and exit easier on their vehicle.
I see that it appears to have a horn hookup; do you know if it also has the circuitry to deactivate the airbag light built-in? Does it move the wheel closer to you? If so, by how much?
The airbag disable is simple. Just rig up a 2.2 ohm resistor to some pins and voila you plug it into the connector in the steering column. Takes about five minutes. Just make sure you do this with the car off.
Corvus
1 - 5 of 5 Posts
