1 - 8 of 8 Posts
Does anyone have a wiring diagram to share for wiring up an xede to an elise ? 06 DBW version onwards ...
Cheers
thanks,
have researched and researched, and have modified the generic wiring diagram from xede to suit ...
can anyone confirm what type of maf we have on the 06 cars ?
Cheers
Stupid question - what do I need to do to remove my XEDE and return back to the OEM wiring structure?
Do you have a bypass plug? If not, then pull the harness and re-splice the OE wires, believe there are 3 of them, plus remove the ground and 12+...fairly straightforward.
If you don't want to mess with soldering the harness, just unplug from the Xede and put the bypass plug on the harness side, and put the Xede on the shelf. If you want to remove the harness entirely, give me a call and I can walk you through it.
1 - 8 of 8 Posts
