Official Elise Parts List
64K views 71 replies 33 participants last post by  Catsailr27
#1 · (Edited by Moderator)
A stock/replacement parts list of the Elise parts I gathered for maintenance Etc. insight or suggestions welcome.
Lotus service parts
ENGINE:
Air Filter:
Toyota/OEM 17801-0D020
Green filter 2319 (online)
Oil drain crush washer:
Part#9043012031 (Toyota)
Oil filter:
Mobile M1-209 (pep boys, Amazon)
Recommended for its filtering quality/build.
Engine Oil ( 2ZZ-GE by Yamaha):
Rotella T6 5W-40 (Walmart)
Mobil One 5w-40 (Better, Amazon)
Pennzoil 5W-40 Europe (Amazon)
Castrol Edge Synthetic 5w-40
Gearbox oil:
Redline MT 90 (online)
Serpentine belt (need consensus on non S/C, S/C, later models, etc) I have a 2005 Non S/C so I'm guessing:
Gates #K060663
AC Delco 6K663
Dayco 5060665
Goodyear 4060663
Napa 25-060663
Non-A/C Non-S/C car: K060559
N/A A/C car NAPA 25-060663
Toyota 90916-02537
Thermostat:
Toyota 90916-A3003
*Note thermostat gasket is sold separately Toyota part number 16325-62010
Coolant:
Peak Global Lifetime 50/50 Prediluted - Closest coolant to stock you can get in the USA - Hard to find, believe it or not Walgreens carries it.
LIGHTS:
Turn signal bulbs front:
WY5W chrome (amazon/ eBay)
Headlights:
Low beam- H1 55w
High beam- H7 55w Osram
WHEELS/TIRES:
Wheel sizes:
Wheel bolt pattern = 4 x 100mm w/
Offsets of +31.3m front +38.0 rear
Wheel size:
Front - 16x6 (6.5)"
Rear- 17x7 (7.5)" some models are the wider width.
Tire sizes (stock): treaddepot.com
195/50/16
225/45/17
Brake Rotors:
Can be turned if above 24mm
Front- Centric Cross Drilled
128.23000
Rear- no idea
Brake pads:
Porter field R4S
TRANSMISSION:
Clutch:
Clutch disc-
Toyota 31250-52100
Pressure plate-
Toyota 31210-12251
Throw out bearing-
Toyota 31230-12191
Gas cap:
Jaguar P/N C2P5270. Made by
Stant Manufacturing UK
Locking cap on reallylightstuff.com
Thank you for the contribution:
Nickshu
#3 ·
Add oil:
Add stock air filter:
Add Thermostat:
Toyota 90916-A3003
Add Coolant:
Peak Global Lifetime 50/50 Prediluted - Closest coolant to stock you can get in the USA - Hard to find, believe it or not Walgreens carries it (I didn't believe it either until I found it there)
#7 ·
You can PM or tag a moderator and ask if it can be a sticky, and if we decide it's worthy or needs to be stuck, we shall sticky it! Seems like a good idea. You can tag users by adding an @ symbol at the beginning of their username. @Coyne
#13 ·
A replacement blower motor for the hvac system. Been trying to get one for almost a week now and the car junkyard that says they have the part still hasn't bothered to pull it and ship it despite daily reminders and encouragement. Im almost 100 percent sure its not a Toyota part but one can dream/hope. Dying to get my new to me Lotus back together by the seller and shipped to me.
Sent from my SM-G935T using Tapatalk
#17 ·
The HVAC blower is:
SPAL 007-A42-32D in 12v form
The resistors are:
Arcol 284-HS50-0.05
Arcol 284-HS50-0.22
Arcol 284-HS50-0.27
#20 · (Edited)
#19 ·
HVAC flap motors:
Bergstrom 2199069
A/C Expansion Valve:
Omega 31-31199 (Case Part No.: 82023542, Jcbcom Part No.: 983/11152, New Holland Part No.: 82023542)
Windshield Washer Pump:
SAAB 90585761 - latest design available in the US, other old Saab and GM part numbers will show replaced by this one
Radio wiring Harness Connectors:
Metra 70-1784
Oxygen Sensors:
Bosch: 0 258 006 127
Rover: MHK 100840
Denso: DOX-2017
Shocks Base Elise:
Fronts
Bilstein F4-BE3-A626-T0
Rears
Bilstein F4-BE3-A627-T0
Wheel Bearings with speed sensors (all Federal cars on all 4 wheels):
SKF VKBA3511
Steering Wheel Clock Spring:
GM 09179297
#28 ·
Long-time lotus owner but I'm new to the form. Great parts listing! I have not had any troubles, other than a busted steel cable in my removable soft-top..., which set me back $500! I'll keep this page bookmarked for future reference!
Thanks again!
Oh, one last thing: Any recommendations on winter tires o_O
#32 ·
owns 2006 Lotus Elise
#35 ·
Many use DeRoure but LT is US centric and we hope members are using lotusparts.com who is one of our paying vendors here in the US whenever possible.
  • Like
Reactions: Devilstar
#37 ·
Anybody have a PN for a 2006 inner rear light cluster, the one with the reversing light in it? It looks the plastic on the inside got damage by something in the trunk so that the tabs that hold the reversing light bulb in place have been damaged. I don't need the lens only the part inside the trunk.
#38 ·
