Hi there! Why not register as a user to enjoy all of the benefits of the site? You may register here. When you register, please pick a username that is non-commercial. If you use a name that appears on any search engine commercially, you must pick another name, whether it applies to you or not. Commercial usernames are for supporting vendor use only. If you want to become a supporting vendor and grow your business, please follow this link. Thanks!
Dear mates,i purchased the gas pump in subject on a famous website where the compatibility with my car was assured. Now it isn't. In fuel tank doesn't fit. There should be an adapter. But I cannot find anywhere. Please help. Thanks
What type of adapter? mounting, electrical, hose? Where did you purchase? Have you contacted their support ? Ifr it was GRP then contact Greg he's great with sales support. I just looked at his offering and it appears to contain adapters.
This claims to be compatible with MOST applications.
The 340LPH E85-Compatible High Flow In-Tank fuel pump includes a wiring harness, pre filter, internal fuel hose, clamps, end cap and rubber buffer sleeve. Every AEM 340LPH E85-Compatible Fuel Pump is tested to flow 340 lph at 40 PSI before it is packaged for sale.
Tested and compatible with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline
Designed for high output naturally aspirated and forced induction EFI vehicles
In tank design
Each pump is tested to flow 340 lph @ 40 PSI
39mm diameter fits most applications
Includes pre filter, hose, clamps, flying lead, end cap and rubber buffer sleeve
No. The problem is in tank fitting. It doesn't fit. The stock yes. This one needs adaption of in tank fuel. In order to stay fix. Must be an adaptor. Should be easy,piece of plastic. But I can't find. And the site claims it fits perfectly...
Related Threads
The Lotus Cars Community
posts
2.8M
members
56K
Since
2002
