Continental / BMW MK60 / MK60E1 / MK60E5 ABS Swap Thread
6.6K views 35 replies 9 participants last post by  chibo
Great info!
I installed one of the “programmable” MK60 units from an E46 M3 before the prices got out of control.
Even with the stock M3 programming and even getting my yaw module installed backwards initially, it was a huge improvement over the stock ABS system.
Instead of dealing with the stock ABS WSS and converting them to a hall signal, I am using the BMW sensors and made custom tone rings that mount to my rotor hats. This also gives me an interface to mechanically change the number of pulses per rev for each axle. So, front is 44 pulses/rev and rear is 48 pulses/rev. The rear matches S3 hub pulse count, so my rear 5-bolt conversion using Exige V6 front hubs doesn’t ruin my WSS setup.
Two observations that appear to be normal:
1. The pedal travel during ABS actuation is significant. At the 2024 SCCA Solo Spring Nats, I talked with other Mk60 conversion users and they confirmed this behavior.
2. The ABS module makes a ticking sound when it is operational… maybe 1.5hz-ish frequency.
