My evora was just at the shop and they adjusted the stereo back to the stock settings. I drove home and my i-Pod worked just fine. Close to home in between songs it stopped. I have been unplugging the i-pod, turning the unit on and off and other combinations. Outcomes varied. Got not reading USB, Got it to work normal and read the song but the counter just stays at 0:00. Pause not on.. I did see an error code of 003 that I will look up to see what it could be. I am wondering if I should reset the unit and or disconnect the battery. I do not want to disconnect the battery as I just had the trunk redone. (previous owner broke the battery cover and the carpet was just hanging) but if I do I will. May be better to just pull the fuse for a minute.
I will get into the manual and search around for a solution but thought I would ask here first.. Thanks everyone.. Open to all thoughts or ideas.
