Hi,
My son is about to pull the trigger and pick up a 2006 Lotus Elise. I noticed the headlamps have silicone around the projector lamps. The dealer said this is because someone had performed a headlight update on the car a while ago.
I'm not from the Lotus world, and this is the 1st car I will work on where the headlamp lens assembly is normally separate from the projector. In a regular car, the headlights are sealed, and the only time you see silicone is because someone tried to fix a light that has a leak where moisture can get in and fog it.
Would this even be the case with an Elise, or is it just a poorly executed upgrade on the lights? When we go tomorrow to look at the car again, I am now aware that there are "halo" kits to put a ring around the lights, which could be what was siliconed; I am not sure. Does anyone have a close-up picture of an unmodified light with the lens still on? Found plenty of pictures of the projectors without the lenses.
Thanks,
Cheers,
Corey
Thanks,
Cheers,
Corey
