Recommended ODB Reader
4K views 8 replies 8 participants last post by  ChrisH
#1 ·
Hi
I am looking for an ODB-II reader for the Exige. Any recommendations? Nod looking to re-program anything, just reset the Check Engine light, get an ECU dump if possible etc.
#4 ·
Actron CP9180
Here's the one I have.
Works great, easy to use.
Regards,
Wayne
#5 ·
Just so you know, any OBD ll reader that you buy will work to read the codes. Additional optional features are freeze frame and live data. Those can be handy when trying to diagnose if you know how to read it.
#7 ·
Let me start by saying that I am not the greatest expert when it comes to OBD readers. I have read most of the other threads covering this topic and gained a wealth of knowledge from other people's experience when it came to finding the right scanner for their Lotus though. What I can tell you from my own experience is, make sure you test whatever scanner you want to get before you buy it, as not all of them seem to work on our cars. Most auto parts stores will let you do this, so it should not a big deal.
Anyway, what I discovered when I bought a scanner for my car is that I like Actron scanners a lot. They were all easy to use, competively priced, and did what they claimed to do. I even tried the really inexpensive Actron 9125, and it worked on my Elise just fine. I actually wound up buying one of these because I don't have the need to regularly do some of the advanced data logging things that the more expensive units can do, and I have some friends who can lend me their fancy units when I want to use them. So, if all you want to do is read and reset the occasional CEL/MIL light, for $50, that is what I would recommend.
#9 ·
If you want to do more than just read and reset codes, I recommend the DrewTech Mongoose (whatever the latest version is). It is an OBD-II interface to the USB port on your computer, so you can monitor and log all OBD-II outputs supported by our ECU (such as sensor levels, fuel trim, RPM, throttle position, etc.). I have used this interface for about 5 years now, and it has come in very handy for diagnosising odd engine problems.
