41 - 60 of 65 Posts
Look what just showed up today (Dolomiti Shifter, and according to Manuel, might be the first one he's shipped to the US):
Initial impressions is this is one solid shifter, I'm impressed just by messing with it on the floor. Probably will be a month or so before I get it installed (doing it along with a few other items, so I need to find the time).
Also, big shout out to @dzcmnl, such a great person to deal with through the entire thing and has been awesome in answering questions about his shifter.
I'll post more impressions (might do a thread on it), once I get it installed, but this is one nice piece of work, can't wait to get it installed.
Does it still use a polymer ball socket at the bottom? Tell me that isn’t so, as I was hoping this one wouldn’t have that.
Have you had a chance to install it yet? I have one sitting on my shelf. I'm in the middle of a move and it's going to be a while before I get to it so I'm interested in the experience of others.
Funny you should just quote me today. There was one item I had to wait on Lotus for. The blue ball style shifters (which my car didn't have since it's an 06), had a spring for the reverse lockout underneath the shift knob and Manuel got in touch with me letting me know I needed that for his reverse lockout to have the correct tension. So I had to order that from Lotus (Part #: A132F0191S). That just came in last week. I was busy last week so couldn't actually install it then, but finally, I will be installing the shifter in the car tomorrow (took the day off work to do it, so I'm committed)!
I'll give initial impressions and such once I get it in and get a drive in this weekend, rest of the week weather wise is looking iffy in my area, but at least I'll be able to test it out for the first time Friday/Saturday. I will post initial impressions hopefully on Sunday/Monday (as long as everything goes good with the install, I don't see it not going good, but as always, you never know).
I think I took the last spring in the US, sorry about that :). I was concerned that the reverse lockout mechanism was loose and rattley until I installed it. Then it all felt very solid. I bought the knob from Manuel. It's nice.
I'm predicting a run on these springs lol. Now it will be a race to order from the UK if it can't be matched here in the US.
owns 2006 Lotus Elise
Yeah, you probably took that last one in the US, lol. When I asked Don from AutoEurope, he said none in the US, but UK had some. It only too two weeks to come in, so not bad. Once I installed it though with the new knob from Manuel, the feeling of the reverse lockout was wonderful. I'm looking forward to getting this in the car tomorrow.
I did a video when I did the ShiftR111. I'll try to do the same when I swap if for this one.
The Dolomiti Shifter install has been completed and I have given the car and shifter a good shakedown with quite a few miles on it, so time for some impressions (I'll split this into a two sections (Install and Impressions)):
Install:
Install was fairly straight forward, took about a day to remove the old shifter and get the new one in, adjusted, and then out for a test drive. So if you have one, set aside a day or so and just take your time. I HIGHLY recommend viewing the videos Manuel (@dzcmnl) created on YouTube on setting the shifter adjustment once installed, he goes through in good detail how to set everything up once you're ready for that part (no instructions on installing the shifter itself, but I'll touch on that now).
Videos Here: https://www.youtube.com/channel/UCbD6Xhzpprh66oeuGy41H_Q
For actually putting the shifter in, it's pretty straight forward, the shifter comes in two sections (the front with the shifter, and the hand brake side). Usually you would have the two pieces separated and install the shifter side first, and then install and attach the hand brake side to the shifter side. Being me, I did it slightly different. I had the full shifter connected, but removed one of the sides of the hand brake and slid the wires in that way and then connected it together, it worked well and gave me plenty of space to sort the wires, get the block/cables in, hand brake in etc..., or you can install it the traditional method of both pieces being separated and combining them, either way works. Picture for reference of how I installed mine by removing one side:
Lastly for the install, here's the settings I did for the throws, I went with the shortest throw distance. However, for the cross gate distance, I went a tad shorter than the longest throw on the cross gate (I don't like cross gears being super close, but personal preference), here's pictures of that:
Throw (Shortest Throw):
Cross Gate (Just a tad down from the longest setting):
Shifter Feel and Driving Impressions:
Alright, the actual reason you're reading this (or skipping the above), what are my thoughts... Quick background, I've had the car now for almost three years with the Inokinetic shift cables I installed the first year I got the car, other than that, Stan's Mod, and Inokinetic front/back engine mount inserts (Side note, seriously, add the inserts, they make a huge difference even with the stock transmission), the rest of transmission is stock. After giving it a good shakedown and putting quite a few miles on it here the last two days, going through all gears, up shifts, down shifts, heel toe, etc... Well... It's absolutely freaking fantastic!
I honestly can't say enough nice things about this shifter, the feel compared to stock is just outstanding. Gone is the vagueness and sloppiness of the stock shifter when putting it into gear from my perspective. The shifts just click into gear now and are so much tighter. I can't stress enough how much better it is in terms of of it being a much tighter and direct shift than stock for myself. It just feels so good going into gear. On top of that, having a shorter throw makes such a huge difference, and it being on the shifter side just makes it easier to adjust if needed, unlike the LETSLA. Every time I shift now it just feels so direct and precise. Don't get me wrong, it's still a Lotus cable shifter so it doesn't solve every issue that presents, but it tightens it up at the least and transformed the shifting for me. Let's not forget about how well its engineered and built too, Manuel did an amazing job designing and putting this together, and the time and effort he put into this product to perfect it shines through from the moment you get it. It is an extremely well built piece of work and what an awesome contribution to the community!
Out with the old and busted and in with the new and shiny:
Thanks for reading my jumbled thoughts, big shout out to Manuel @dzcmnl. The product he built is top tier and the engineering of it is so precise and so smooth, it really is a huge step above stock (can't comment compared to the Inokinetic one, but maybe @me73 can provide that comparison if he installs his).
Let me know if you have any questions, but in summary, Dolomiti Shifter is absolutely amazing, can't say enough nice things about the shifter and the way it feels and Manuel himself for making it and supporting it!
Great report on an excellent piece of engineering. Manuel has thought of everything - like his eccentric shaft to adjust the cross-gate spring.
This is the full solution for Blue pivot ball failure on any factory 07>17 shifters, or for 04>07 cars that just want more precision and adjustable lever throw.
I see that he can also supply spherical rod ends for your factory cables, as come standard with SSC cables.
I've now used them both back to back.
I set the Dolomiti to about stock shift throws. I'd say they're both extremely well constructed and the shift feel is crisp and mechanical in both. If blindfolded, I don't think I'd be able to tell the difference in the feel going from gate to gate between the two. The bases are both really solid and eliminate motion. The most significant difference being that the Dolomiti locates the lever towards the passenger far more than the ShiftR does. So it's further from the steering wheel but gives your leg more room. With the first shift, I was used to either position so I don't think it's a big deal.
As far as construction, both are really nice. The ShiftR's mechanism is a piece of art. The Dolomiti is more conventional, but the entire base mechanism is machined pieces, as opposed to the cut base plate that Inokinetic uses. That and the crazy beautiful aluminum cable retention block make the Dolomiti something that could easily be left naked and appreciated. I liked the way the e-brake bridge is designed and constructed on the Dolomiti more. It's easier to assemble and to keep the cables and harness routed without any interference with the brake. I noted that the Dolomiti's ball joint has lower resistance than the ShiftR. Both are super smooth and well built, but the shifter on the Dolomiti moves around much more freely before the shift cable is attached, which I have to imagine helps with the feel of the shifts maybe just a bit. The Dolomiti's reverse lockout is simpler and doesn't need set-up but the mechanism is guided by some sleeves that have a bit of slack to allow motion.
The Dolomiti does fit a bit better under the stock console. It doesn't interfere with the few spots that the ShiftR does.
I had a noise in my shifter from vibration that was coming from what I think is the transmission in the ShiftR. I was curious to see if the Dolomiti did the same thing and it does, maybe even a bit more. So I'll be living with that :)
Overall, I'd say they are both equal on function. They are very well constructed and I don't see any reason why one would last longer than the other in the long term. The Dolomiti does allow you to adjust shift throw and has the stick angle towards the passenger. So I don't think you could go wrong with either one, it comes down to the features that you care about.
Thanks to Brandon for his review.
A couple of tips:
  • The Dolomiti shifter is designed to let the lever has the same angle both on reverse (on the left) and both on 5/6th gears (on the right): this allow the shift cable to work in it's better conditions. Also this let the neutral position to be a bit on the right (not as much as shown in the video min 18:25, where the shifter was not already registered). In my project this was a double win because I leave much space to the right leg that in the stock conditions hits the lever when you are downshifting from 3rd to 2nd and don't allow the 2nd to engage.
  • The Dolomiti comes with no hand brake screw (reuse the stock one), but on new kits I will include that screw. The one shown in video is for fixing the Ergal 7075 base.
  • Here the setup tutorial to follow after shifter installation (4 steps): Dolomiti Shifter adjustment, #1/4: lever stroke adjustment - YouTube
  • The lever can be moved a bit on the left if wanted, with a simple modification on one shifter component. Many configuration are allowed on the Dolomiti shifter.
Manuel
Not directly related to the shifter itself but more eye candy. A quick picture of the Dolomiti shifter now safely tucked away inside the GRP exposed center console that I had upholstered and just as proof that the console and shifter fit quite well together (only things I still need to do is fixing up my wire hider I made (making it look nicer) and the top portion changing to a matte CF instead of glossy, but that will be done this winter):
41 - 60 of 65 Posts
