OK, I will try to make this as brief as possible, but it has been an issue since I drove the car off the dealer lot. In fact, the problem caused me to slam a curb and I had to replace the front clam & crash structure
The symptom: Every time the brake pedal is pushed, the pedal level and amount of braking is different. Extremely inconsistent, everytime I hit the brakes it's a crap shoot on what is going to happen. Just moving at a constant speed, depressing the brake pedal for a few seconds, off, back on will have a different braking effect. When I press bakes quickly, the pedal is very high and no matter how much pressure that I put (both feet, as hard as I possibly can), the brakes do nothing (maybe a slight drag)... I have found that when this happens, if I let off the brake pedal, then slowly depress it, the brakes somewhat function. You can imagine how tough it is to autox with this braking inconsistency.
Parts: It did this with the OEM pads, so I did replace with the Porterfield R4S (If I remember correctly), problem did not change... I assumed the pads where bad, so I bought Pagid Blue pads for all 4 wheels. Again, no better.
After blowing through a wall of cones in a hard braking area at last weekends AutoX, I decided I HAVE to solve this problem. So, I ordered a Motive bleeder, RBF600 and stainless steel brake lines. After LotusTalk searches I found that I could disable the ABS by disconnecting on the front passenger wheel. I did.... WOW, the car stops on a dime now, it has NEVER stopped even remotely as good as it now does (with ABS disabled). The brakes are now consistent, and stops with one leg moderate pressure.
Alright, to the burning question, what is wrong with my ABS? This can't be normal ... I had ABS on my S2000 and it never behaved this way. I will go ahead and install the SS lines and flush the fluid, but now I don't think that it will help the problem, it seems to be 100% related to ABS...
Any ideas/suggestions would be greatly appreciated.
Thanks,
Thanks,
