ANything wrong with using teflon tape on rear diffuser bolts?
1 reading
4.4K views 14 replies 12 participants last post by  kverges
#1 ·
Hi All,
I read some threads that people were losing thier rear diffuser bolts. :(
Wouldn't using teflon tape on the bolts hold them in place and make them very resistant to vibrating loose? I know we can use threadlock as well (blue stuff right? for temporary bond) but if given a choice I rather go teflon tape.
I goof around a lot with RC cars and the teflon solution has always fixed a bolt that kept vibrating loose.
ANy reason why not use teflon instead of threadlocker?
#3 ·
The quick release kit for undertray and rear diffuser works very well, Sector 111 sells them. It uses dsuz fasteners. Had it on my first elise will put on my new one. Takes about an hour to install the set, from then on it's about a 5 minute process to take the undertray/diffuser off.
Chris
#4 ·
I have never heard of teflon tape acting as a thread locker, it is more like using antisieze...But perhaps under certain conditions the extra material in there from the teflon tape would do the job. Wouldn't threadlocker be easier?
Mark
#6 ·
Guys...
Teflon tape will not prevent a bolt from backing out. It is to seal against leaks. Use it on any bolt that involves contact with a fluid (AN lines, sensers in the block or intake manifold, etc.).
I'd use blue thread locker on those bolts, but understand they will be a bitch to take off. Red is a huge no no. You'll probably break the bolt trying to get it off, or strip the hole.
The dzus solution is the best. Easy on, and easy off.
#7 ·
The bolts in question are not the ones you replace with DZUS fasteners. The smaller Number 8 bolts all over the place get replaced with the quick release kit. But they tend to not fall off as they use Tinnerman style nuts which have an automatic spring force to hold them in.
The ones that back out under vibration are the larger button head allen bolts that go through the diffuser and the pan under the engine (two per panel) and into the chassis. These are the ones I put a dab of blue loctite on. Just a small dab. And I still keep extra ones for replacements.
#9 ·
I tried Teflon tape on one of the two larger bolts (right side bolt, to be exact) because for some reason the hole and threads don't seem to be the correct size anymore (?? WTF :confused: ). I've never tapped any of those bolt holes so I'm not sure what the issue is. If I use any of the other bolts, they all fit loosely -- as if the hole is 0.5 mm too big. Although, some bolts seem to fit better than others. So now it comes loose (obviously) all the time.
Anyway, the Teflon definitely doesn't work. The reasoning was maybe if I wound enough of it around to increase the bolt diameter, it would hold.
So any suggestions? I've though of filling the hole with some sort of epoxy cement, and then drilling and tapping it out back to the correct size. Any thoughts or other suggestions? To make sure, the images shows exactly which bolt and hole I'm talking about (since some seem to be confusing them with the smaller 8 mm side bolts):
#10 ·
conan-
this solution was reported in another thread:
The first time I went to take off the undertray, one of the 8mm bolts was half loose because one of the 8mm frame nuts was stripped. I helicoiled it, it has been working fine since.
from this thread:
http://www.elisetalk.com/forums/showthread.php?t=46296
i too have one insert that is beginning to loose it grip on the bolt. i'm probably going to go this route for all four at some point.
#11 ·
conan-
from this thread:
Thanks for that reference. I read that thread when I search for "rear diffuser bolt loose" but I missed that post in there. Now I need to google "helicoil thread" because I've never heard of doing that.
#14 ·
Mine are staying put just fine now that I can tighten them.
