21 - 40 of 141 Posts
I was wrong, the U-Tube is on the dual oil cooler models as well. It was hard to find though, and I tugged and tugged on it and couldn't get it pulled off to the side to get a very good visual inspection. However, feeling it - it didn't seem to feel damage.
Theres also no way to check it with just the rear tires off, you must remove the under tray.
Discussion starter · #22 ·
You are right, my under try was off when I too some pic's from the RHS rear fender well. Here's a pic from that angle with the car running, even with all that rubbing ont he tube, it was just barely dripping. The blurry thing to the left is my phat BADARAONE.
Man, and I was all ready to have some good fun at MSR CW this past Saturday. Thanks:clap: Toad for letting me get a few fun laps in your Elise:coolnana::up:...
Interesting...
I checked mine as well and the u-tube was zip tied down to one of the oil cooler lines :shrug: . Not sure if this was done by a dealer or the PO. I don't see any "bad" abrasion, and I'll try to post a pic to show all later. The last pic is my attempt to tie the u-tube to the larger cooling line? I'll haver to check it at the next oil change. Thought others might be interested in seeing another...
Jim B.
Jim B.
That's the way mine came from the factory as well.
You think a single zip tie is enough to keep this from vibrating and wearing through? :confused:
That seems like a last minute fix on the assembly line when someone said: "Hey look... that might be touching when the engine is running"
Supervisor: "Just zip tie it to the closest thing, it'll be fine. No need to report this to the development engineers"
:thwack:
Thanks Yaudi... I will check mine this weekend when I do an oil change.
Discussion starter · #27 ·
I don't think mine was ever zip-tied from the factory:sad:. For reference, I picked her up in Mar '05.
From the pix BlueMustang has shown, there still some rubbing even zip tied. Can't say zip tie of steel on aluminum is an optimum solution.
Me, I'd get a short length of hose, split it, and tie whap it around any sign of abrasion then re-tie-wrap the whole thing back down. A more elegant solution would be to get a short length of u-shaped hose and bypass the whole mess - it even saves a few ounces.
This is why I come to elisetalk. Thanks Yaudi.
+1!!!! Thanks Frankie! I know you push your Elise hard and its great of you to share your findings with others on e-talk. :up:
This is exactly what I did, mine was tie-wrapped from the factory and this probably slowed down the wear but it was worn (not to the point of leaking though at 25k miles)
Will check mine in the spring...before warranty runs out.
Mine is also attached with a zip tie. Do I need to do something to prevent future disaster?
Mine was zip tied and when I removed the tie and checked, I saw an area that was about to burst open. I also split a radiator hose and wrapped it around the U Tube and then zip tied the whole thing into place. Shouldn't be a problem now. I suspect there will be quite a few Loti with coolant leaks in the future.
Did a bunch of work on my car today and remembered to look at the u-tube. It looked like it was getting pretty close to wearing through. I've got about 21,000 miles on the car and I think it might not have made it another 5,000. I wrapped it in rubber and ziptied it, but I'm thinking about a longer term solution to put in place the next I have the car up on stands.
I really appreciated this thread.
Found same situation on my car; tie-wrapped heater hose around U and tie-wrapped the whole thing out of the way.
Thank you very much.
CHECK YOUR "U-TUBE" SOON
This is not just a high-mileage problem.
I just checked my connector for the feed and return hoses and there is wear at 6000 miles. Granted, I do a bit of spirited driving on twisty mountain roads but nothing excessive.
Here is my connector on my 2007 Elise, again at 6000 miles:
Here is what I used to shield the connector for now, zip-tied around the tube. It is a rubber shim for bicycle handlebar attachments (lights, heart rate monitors, etc). I figure the rubber will help hold the connector in place, buffer any movement, and protect the connector. Really it is the only thing I had lying around ;):
Here it is in place:
And again:
Don't let this slide too long or you'll be sorry :no:. Check your feed and return hose connector soon.
YAUDI, thanks for the tip-off. :up:
Just checked my car's U-tube while changing the oil. FYI...my car was bought in 5/06, has 10,800 miles, is used as a weekend canyon carver and also tracked about 6 to 8 times per year.
The U-tube looked slighly "polished" from rubbing, but it did not appear to be damaged.
I cut a 2.5 inch length of rubber heater hose, split it down one side, notched it in the center of the split so it would bend easily, zip-tied both end in place, and zip-tied the rubber wrapped U-tube to the oil return lines. It has a nice cushion now and isn't going anywhere!
+1 for split hose and cable ties repair
I was just under my car, checked the U-Tube and it had a small wear mark on it, I bet it would have gone in the next 10K. I covered it with split hose and tied it back with the hoses that run along the firewall.
I just checked mine. Feb 05 Build. 17K miles. I am showing a bit of abrasion.
I shielded it with heater hose as well.
I will soon check ( as soon as the weather breaks) the other LOONY Elises that I regularly change the oil on. One is a Nov 04 Build and the other is a Sept 04 build. Both with low miles. Let you know what I find.
Lotus must have changed something for '07 (or maybe it's a S/C thing) -- my, as well as Carl's, car doesn't have that U-tube???
