Creaking Binding Noise on a Evora GT
4.5K views 11 replies 9 participants last post by  Lckitty
#1 ·
Hey!
Just posting to see if anyone on here has had front end noise with there Evora GT yet. I have around 8k miles.
Noise mostly occurs while turning on a incline and decline but will do it while turned on a flat surface. No noise going over bumps or while driving in a straight line
If you could imagine the noise of a ziptie on a wheel constantly hitting something is what it sounds like. (binding/creaking)
Any tips would be great! Thinking of replacing my sway bar bushings for giggles to see what happens.
Thanks!
#2 ·
owns 2006 Lotus Elise
#4 ·
Could be this common issue:
#5 ·
Posted in post#2
Reactions: Slobdog
#6 ·
Does it only make the sound at low speed turning the wheel? I had the same issue and it turned out to be the bolts on the power steering rack were a bit loose. Very easy to fix, just drop the front panel and you'll see the screws securing the bracket and power steering rack. I just snugged them up and the problem was resolved.
Cheers,
Zoomby_U
#8 ·
Hey!
Thanks!
Hey!
Thanks!
I’m having the same binding noise with my 400 with 16k miles. I haven’t had the opportunity to get under the car yet, but when I find the issue, I’ll let you know.
