81 - 100 of 228 Posts
Since there isn't a single place anyone new (or not new) to the Evora sub can go to find parts cross-references, I figured I'd start a thread that will hopefully grow into that definitive source.
To start us off, I'm dumping the stuff I've been keeping track of over the years. If anyone finds something amiss with something posted, please let me know and I can edit. Feel free to contribute a post if you don't see something listed.
A/C Compressor
Toyota/DENSO Part #: 8832042120
UAC Part #: UAC CO 10856C (FROM A USA TOYOTA RAV 4 3.5L V6 2006-2012)
A/C Dryer/Receiver
PACCAR Genuine Parts
1711509PAC (for a Peterbuilt)
1400604PAC (cross-ref)
Alternator
Toyota 27060-31082
Denso 104210-2071
ARB Lube
Super Lube (PTFE)
AquaShield (green snot)
Battery Alternatives
AutoZone T6-DLG (DuraLast Gold)
Interstate MTP-91 (Group 91)
Duracell SLI48AGM (Group 48)
Serpentine Belts
Gates K070822 - NA
Gates K071130 - S
Without AC Compressor (NA) - 7PK-1988
Belt Tensioner
Toyota 16620-31040
Idler pulleys
2x No2 idler pulleys (Toyota 16604-31020)
2x Idler cover plates (Toyota 16649-31020)
Brake banjo crush washer
Pegasys Racing 3241-3/8
Brake Pad (Front)
EBC Redstuff DP3036C
Ferodo DS2500 - FRP3083H
Brake Pad (Rear)
EBC Redstuff DP3060C
Ferodo DS2500 - FRP3115H
Brake Switch
GM/Saab 51 06 141
SLS334 Stop Light Switch
CHMSL
Perei HS25
MG Rover XFG000150 (clear lens)
MG Rover XFG000140 (red lens)
CHMSL Connector
BMW 61-13-8-373-583
Clutch Slave Cylinder
Toyota 31470-12190 (Avensis, Verso, Corolla Verso, RAV4 Diesel)
Aisin CRT-087 (Toyota Avensis)
Valeo 804777
Coolant Cap
Toyota 16475-28140
Door Hinges
Ford Focus (?-1998-?)
Headlight Washer Pump
Bilstein Febi 26274
Headlight Washer Nozzle Cylinder
Mercedes-Benz W163 1998-2005 (transfer OE spray heads)
Thermostat
Toyota 90916-A3003
Thermostat gasket
Toyota 16325-62010
Crankshaft Position Sensor
Toyota 90919-05060
Dome Light
VAUXHALL ASTRA/GM/Chevy Spark 13126729
HID ballast
03-05 Audi A4 / S4 89030471
OEM Valeo LAD5GL 89035113
Mass Air Flow
Toyota part # 22204-31020
Denso part # 197-6110
O2 Sensors
Bosch 0258006127
Bosch MHK 100840
Lotus A117E6007F
Denso DOX-2017
Rover MHK 1008 40L
Bosch 0 258 006 915 (Universal)
Oil Filter
TRD PTR43-00082
Toyota 04152-YZZA1
K&N PS-7020
Mobil 1 M1C-251
Wix 57047XP
Wix 57047
Parking Brake Shoes
Peugeot 406 (8B),406 Break (8E/F), 406 Coupe (8C), 607 (9D,9U) =>1995-2005 - LPR 08400
Diameter (mm): 185
Width (mm): 30
Power Steering Pump
Toyota 44310-07040 W-23
Spark Plugs
Denso FK20HR11 (NA)
Toyota 90919-01247 (NA)
Starter Motor Brushes/Yoke (NA & S Manual Transmissions)
Hitachi S114-945
Supposedly S114-943 brushes fit
REMIUM BRUSH ASSEMBLY-NISSANS & INFINITY WITH HITACHI STARTERS
For : • Hitachi PMGR Starters
Also See: 68-8129;68-8137;69-8118
Used On: BMW (2001-2006) , Infiniti (1996-2001) , John Deere (1998-2005) , Kubota (1999-2010) , Nissan (1995-2010) , Yanmar (1994-2003)
Replaces: Hitachi 2114-73105, GD213648-D, Nissan, Infiniti 23378-0M300
Unit Nos: BMW 12-41-1-354-823, 12-41-1-740-373, 12-41-1-740-374, 12-41-1-740-375, 12-41-1-740-379, 12-41-7-515-391, 12-41-7-515-396; Bosch 0 001 108 401; Denso Europe DSN954, DSN955; GM 10455018; Hitachi S114-800, S114-800A, S114-800B, S114-801A, S114-801B, S114-801C, S114-801CR, S114-801D, S114-801E, S114-802A, S114-802B, S114-802BR, S114-806, S114-806A, S114-806AR, S114-815, S114-815A, S114-817, S114-817A, S114-821, S114-821A, S114-822, S114-822A, S114-822B, S114-833B, S114-844, S114-844R, S114-902, S114-902A, S114-902B, S114-902R, S114-922; Hyundai 36100-2Y000; John Deere AM879072; Kubota T1060-16800, T1060-16804; Letrika (Iskra) 11.139.430; Letrika (Iskra) Sales IS 9308; Letrika (Iskra) Tech. AZE2198; Nissan, Infiniti 23300-0M200, 23300-0M200R, 23300-0M201, 23300-0M300, 23300-0M301, 23300-0M302, 23300-2J260, 23300-2J261, 23300-2J261R, 23300-2J262, 23300-2Y900, 23300-2Y900R, 23300-31U00, 23300-31U01, 23300-31U01R, 23300-31U02, 23300-31U02R, 23300-63J02R, 23300-8H00R, 23300-8H300, 23300-EN200, 23300-EN200R, 23300-EN20A, 23300-EN20B, 23300-EN21ARE; Prestolite 20513073, 20513073; Renault 7701065384; Valeo TM000A24601; Valeo Tech 579377; Yanmar 118400-77010, 129608-77010, 129698-77010
Lester Nos: 17146, 17695, 17702, 17713, 17745, 17779, 17980, 17982, 18219, 18288, 18290, 18440, 32265, 6330-HISteering Wheel Slip Ring:Ford 2M51-14A664-DE
2002-2005 Focus
Starter Motor Brushes/Yoke (NA & S IPS Transmissions)
Complete Starter: Toyota P/N 28100-20021, Denso 428000-1841
Brush Holders/Yokes:
Denso: 228000-9900, 228000-9901, 228000-9902, 428000-1080, 428000-1081, 428000-1840, 428000-1841, 428000-4310, 428000-4311, 428000-5870, 428000-5880, 428000-5903, 428000-5904, 428000-5913, 428000-5980, 428000-5981, 428000-5983, 428000-7492, 438000-0630,
GM: 88975515
Lexus: 28100-0A010, 28100-0A010-84, 28100-0A011, 28100-0A011-84, 28100-0P031, 28100-0P032, 28100-0P080, 28100-0P080-84, 28100-20020, 28100-20020-84, 28100-20021, 28100-20022, 28100-28040, 28100-28041, 28100-28041-84, 28100-31100, 28100-31101, 28100-31102, 28100-36120
Scion: 28100-20020, 28100-20020-84, 28100-20021, 28100-20022, 28100-28040, 28100-28041, 28100-28041-84, 28100-31102, 28100-36120
Toyota: 28100-0A010, 28100-0A010-84, 28100-0A011, 28100-0A011-84, 28100-0H090, 28100-0H091, 28100-0H091-84, 28100-0V010, 28100-0V011, 28100-0V012, 28100-20020, 28100-20020-84, 28100-20021, 28100-20022, 28100-28040, 28100-28041, 28100-28041-84, 28100-28060, 28100-28070, 28100-28071, 28100-28072
Tail Light Connectors
TE Connectivity AMP
Econoseal III 070
344265-1 (male 6-pin)
345259-1 (female 6-pin)
TPMS Valves
Autel MX 433 - Needs Autel programmer
Schrader 20159 ou 13227143
Convient également :
Élise 2008+
Exige 2008+
SAAB 9.3 07/2002 -- 04/2005
SAAB 9.5 07/2002 -- 12/2008
Câble de lève-vitre
1,6 mm (ou 1/16") - 31 3/4" de longueur
Ensemble virole et butée Home Depot
Lame d'essuie-glace
Bosch Aerotwin AM26U (OEM)
Bosch Aerotwin AP26U (symétrique)
Valeo 900266B sans cadre ULTIMATE 26" toutes saisons
Moteur d'essuie-glace
Courage de 1995 VW Golf (Bosch)
Buse de pulvérisation de lave-glace
Ford Focus MK4 2011+ gicleur de lave-glace avant chauffant (type brumisateur) - 1708797
Fusibles du panneau de fusibles avant et arrière
MTA MiniVal (profil standard)
MTA MaxiVal
[/DEVIS]
Bonjou,
Je suis Yann de France nouveau sur lotus talk et je recherche comment refaire ma boîte de vitesse d'evora s de 2011 savez-vous qu'elle sont les références Toyota à acheter
Bien cordialement Yann
Please post in English on LT thanks!
owns 2006 Lotus Elise
Any chance there's a cross-reference for clutch parts? Doesn't seem like Lotus would have just fabricated their own flywheels and pressure plates.
Discussion starter · #93 ·
The service notes say the flywheel is a cast iron CMS C500, but it doesn't mention the friction disc, which I believe is from AP Racing. They're actually fairly solid, but if you're replacing them, you might as well get S2 clutch parts, as they're more readily available, and more cost-effective.
Are the clutch parts interchangeable between the S1 cars and the 400?
Discussion starter · #95 ·
Yes. There are a few posts here (maybe @donour? I can't remember exactly) about clutch changes and parts used. I believe the S2s have a different flywheel though, which is lighter mass IIRC. There's also aftermarket options too, like the stuff MWR offers.
@Tweetdriver63 @agentdr8. There are 2 S1 flywheels (NA 19lbs and S 12lbs). I'm not sure if the S2 flywheel is differnent, but I suspect it is similar to the S1S version. You can certainly mount a 400/GT pressure plate + friction disc + flywheel on any Evora. The timing ring and the trans are the same.
donour
PS: don't forget to get the right depth release bearing!
