121 - 140 of 228 Posts
Edition to O2 sensor:
22mm Hex, 22 - 36 ft. lbs
Precat & Postcat, S1 and S2, Fed GT
OE sensor type: LSF 4, any sensor with same construction will work
Lotus:
Bosch 0258006127 (UK only), 568mm tail = Lotus A117E6007F (US,UK), 568mm tail
Rover interchangable parts:
Bosch MHK 100840 (UK only, discontinued?)
Denso DOX-2017 (UK only)
Rover MHK 1008 40L (UK only, discontinued?)
Bosch Direct catalog:
Bosch 0 258 006 915 (Universal) DOES NOT FIT, different construction
Bosch 0 258 006 615 (Universal) Direct Fit, with heat sleeve
-- Bosch 16978 (Audi,US,UK) Sleeved, 1720mm tail, REQUIRES REPIN
-- Tested, working, best solution in US ($75)
Bosch 0 258 006 602 (Universal) Fit, NEED HEAT ISOLATION SLEEVE
-- Anything with number above from thecatalog will fit. Pay attention to tail length
OE sensor LSF 4 should be interchangable with latest LSF 4.2
Please see attached Bosch Catalog for reference.
TPMS - Schrader part # 20159 was superseded by 29204. I can now confirm that these work and no programming was required.
Brake Master Cylinder: Jaguar C2Z9669
I have verified and tested compatibility on a 2011 Lotus Evora.
This part is supplied by Ate Brakes, a subsidiary of Continental. Lotus does not sell the master cylinder and brake booster separately. I reached out to Ate. While very nice, they don't have any compatible part available to the after market. Searching through their catalog, I found that early 2010s Jaguars have the same dimensions. 2009-2015 Jaguar XF is the same. Earlier XJ is probably the same as well. I bought one for US$40 off ebay and it works great.
Even better than the one Elise spares selling for ÂŁ345.
Does anyone know what vehicle the windshield rear view mirror is from?
Sorry, late reply to this, but after a bit of trial and error I can answer this: Nissan Note (mk2/E12).
I'm pretty sure there are a number of other cars that share this mirror too; The Magna 05028 mirror appears to be shared amongst a bunch of Renaults, Citroens & Nissans, although the attaching stalk varies, so you might need to retain the existing stalk and reattach the mirror mechanism if you get, for example a Clio mirror. I just bought a second-hand Note mirror however and the whole assembly is identical - you simply slide upwards to detach and replace.
Lotus:
-- Bosch 16978 (Audi,US,UK) Sleeved, 1720mm tail, DIRECR REPLACEMENT
The Bosch O2 Sensors #16978 ARE NOT a DIRECT REPLACEMENT for the Evora.
The Connector Plug is Larger than the OEM Lotus Sensors - See Photo.
They also gave Low Voltage Codes P0137 and P0157
Lotus:
The Bosch #16978 ARE NOT A DIRECT REPLACEMENT for Evora
The Connector Plug is Larger than the OEM Lotus Plug - See attached Photo
They also gave Codes P0137 and P0157,
Low Voltage Bank 1 Sensor 2 and Bank 2 Sensor 2
They also gave Codes P0137 and P0157, View attachment 1346834 Low Voltage Bank 1 Sensor 2 and Bank 2 Sensor 2
You are right about the plug not being the same. The sensor pin themselves are the same so I did repin them and they worked. For anyone do not want to repin or have no tool to do so, just cut the wire to length and put butt connector and insulator on it. My post will be corrected.
But I do NOT encounter low voltage code you described in my 1500 miles drive after the swap. With counterfiet bosch sensor on the market, yoour milage might vary.
The OE sensor is LSF 4 and the universal kit Bosch 0 258 006 615 is LSF 4.2. From data sheet and my experience they ARE interchangable. Anyway in theory if you spllice any LSU 4.2 sensor and connect to the OE connector, it will run no problem .
A couple more to add to the list. I could not find the Toyota part number for the o-rings to the oil cooler adapter plate. I ordered the Lotus ones but as everyone knows Lotus parts are as slow and that is all that is holding me up on atempting a start on the engine. Took the adapter to work and sized them to Aviation o-rings.
A132E0070F is a M83461/1-229
A132E0071F is a M83248/1-912
A couple more to add to the list. I could not find the Toyota part number for the o-rings to the oil cooler adapter plate. I ordered the Lotus ones but as everyone knows Lotus parts are as slow and that is all that is holding me up on atempting a start on the engine. Took the adapter to work and sized them to Aviation o-rings. Probably
I have one A132E0070F and one A132E0071F. If it would help speed things up for you, I could mail you them and you can just mail me the ones you ordered from Lotus when you get them.
Just let me know....
Thanks for the offer but those I pulled do fit exactly and will work. Guess I will have some extras when they arrive.
Evora GT seat tilt mechanism parts
SPX release left #A132V6323S $35.00 each this will include everything to replace a broken release mechanism.
SPX release right #A132V6324S $35.00 each this will include everything to replace a broken release mechanism.
verified Toyota replacement parts for N/A evora Oil Pipe No.2. the first time i did this i only replaced the lower washer and i still had a slight leak. Second time, i decided to replace everything since it was only about $50. Parts are still available at Toyota dealers
lower union washer - Toyota 90430-16016
upper washers - Toyota 90430-16017 (2 are needed)
banjo bolt - Toyota 90401-16043 (2 are needed if you plan to replace the bolts)
oil pipe no.2 - Toyota 15772-31030
