Help- Long beep after I set alarm
2K views 10 replies 10 participants last post by  Dmbrown34
#1 ·
Hello,
for some reason after I set the alarm I get a long beep which lasts for about 10-15 seconds. Does anybody know what this signifies?
#4 ·
If that doesn't work, try flipping the light in between the seats to the off position...
#5 ·
If all else fails............read the alarm manual
#6 ·
is that anything like RTFM?..rotfl
there are really so many details to the overall management/use of these cars that it's not easy to follow.
maybe a 6 month course would help me....can i blame it on old age?:drool:
sam
#10 ·
Along with the beep, the light on the dash blinks out a code. The number of flashes indicate what the problem is (at least somewhat). The codes are listed in the alarm manual, and I think in the owner's manual. They are also posted in a couple of threads on the forum.
Typically, you will get one of two codes. One indicates that something isn't closed - the doors, the engine cover, or the access panels on the front (it's often this one if the covers aren't on just right). The other common code is usually about the motion sensor - the interior light has to be positioned in the down position and sometimes it gets "bumped" up (yes, the light circuit is tied into the motion sensor power).
