Hello!
I recently bought a 2011 Evora S and have put on just over 1k miles. The car has its quirks and noises.. but recently I've noticed something more concerning.
On/Off throttle (even light acceleration) under 3k RPM there is a noticeable 'clunk' from the engine bay. Over 3k RPM I don't notice the sound at all, and the lower it gets to 1k RPM the clunk seems worse.
No noise under hard braking and no seeming difference under increased throttle pressure. Could this be motor mounts? It had the innovative mounts installed by the previous owner in 2022 with only a few thousand miles added since. Anyone else have this issue with the innovative mounts? I would assume with mounts it wouldn't be RPM dependent?
Might be a dumb question, but what would be the easiest way to check for wear? Can I see mounts from inside the bay or do I need to get under the car? Any other test I can do to check to determine if this is the mounts? Would really love to enjoy the car the last few weeks of fall before I put it away for the winter, but I'm nervous to drive it now.
Thank you!
Thank you!
