I've got the Fumoto oil drain valve with nipple. I'm contemplating cutting an access hole in the engine undertray to allow access to the valve and attached hose, thus allowing removal of the oil without removing the undertray. I suppose this process could work with the standard plug, although the access hole might need to be a bit larger.
Has anyone tried this? If so, how did it work?
Does anyone think that there would be significant airflow issues resulting from an appx. four square inch hole? If so, it should be possible to fit a removable rubber cover.
Thoughts? Other issues?
