You can certainly find other threads about replacing headlight bulbs in the Elise, but I figured I’d share my own experience. I read through lots of those threads, and decided to go ahead and order these LEDs:
Amazon.com: PULILANG H7 LED Headlight Bulbs, 60W 16000lm, 360 Degree Full Emitting Super Bright LED Headlight Conversion Kit, 6000K Xenon White,pack of 2: Automotive
And while I was at it, I replaced the parking light bulbs with these:
Amazon.com: AUTOGINE 10pcs Super Bright Error Free 194 168 175 2825 W5W T10 912 LED Bulbs Xenon White 3030 Chipset for Car Interior Dome Map Door Courtesy Trunk License Plate Lights: Automotive
As I understand it, prior to 2007 used H7 for the high beam, and H1 for the low beam, whereas 2007 and on used H7 for both. So I ordered four of the H7s for my 2009. The H1 format of these same LEDs was recommended by darkSol in this thread, which is where I got the idea to order mine:
HID vs LED (looking to change since clam is off)
darkSol’s experience seems to reinforce the ideas that a round LED array should work better than a flat, two-sided array, so I stuck with round.
I had the front wheels off to get new tires put on them, anyway, and without them in the way it was super simple to replace the headlight bulbs. All I had to do was remove the front piece of the wheel well liner, and the headlights were right there. I was able to pull the covers off of both the high and low beam accesses, unplug the bulbs, release the spring clips, and replace the bulbs. The parking light holder just twists a partial turn and pops out, so it’s no problem. Note that this would be an impossible task (or nearly so) with the wheels on.
Important note about the LEDs I bought: the metal flange that mounts beneath the spring clip on the headlights actually comes off of the LED/fan assembly. Before I figured this out, I installed the first two LEDs by removing the spring clips from the headlights and reattaching them with the LED assembly inside of the spring. That was a big pain. I actually giggled with glee when I accidentally figured out that the flanges were removable whilst replacing high beam #2. I found that there was plenty of room inside of the headlight assemblies for the in-line power regulators that are attached to the LEDs. I suppose it’s possible that they’ll rattle around in there and cause trouble, but given their low mass and the fact that their movement is hampered by wires on both ends, I don’t think that’ll be an issue.
I haven’t yet driven the Elise in the dark to see how much these LEDs compare to the halogens they replaced, but based on other posts I’ve seen I can’t imagine I’ll be disappointed. If nothing else, they certainly look better in bright-white. Here’s a comparison part-way though the replacement process. You can’t tell that they’re brighter (they definitely are) since both side saturate the camera. But they’re nice and white:
