Split Bushing in Rear Hub Lower Link
1 reading
1.5K views 10 replies 6 participants last post by  shashi27
#1 ·
Hi. I’m replacing my bushings in my upper and lower links. Removing the bushes was surprisingly easy using a puller. I’m replacing with purple poly bushings from SJS in the morning after a little cleanup.
What is the purpose of the split bushing (#14) in the pic from the parts manual? I removed my lower link without doing anything with this split bushing but does it need to be removed to reinstall the link with the new poly bushings? Don’t recall ever seeing anything like this is a suspension before.
Thanks.
#2 ·
I think it allows the lower link stud to compress the bushing center without putting undue stress on the carrier (#1). As in not pinching/cracking the ears it goes through.
Bushing is notorious for corroding in place and being a pain to remove, but it should be able to slide in its bore on assembly.
#4 ·
Both of those split bushings were completely frozen in place in two carriers that I salvaged from an '89. If that's the case with yours, I suggest that you drill them out to a wider ID and free them by cutting an opposing split with a mini hack saw blade. A strong press risks breaking off the carrier ears. I installed SJS's stainless steel replacements lubricated with anti-seize.
#5 ·
It doesn't need to be removed (and shouldn't be), but you should ensure it is not corroded in place. As noted above, it should slide to take up any slack when tightening the assembly.
Reactions: shashi27
#7 ·
It will take a fair amount of effort to move it, the act of tightening the nuts on the stud should normally do. If you can't get the control arm into the existing gap you will need to use a large c-clamp or similar to push it outwards a bit. Use a socket that has an ID larger than the bush on the outer side to give it somewhere to go. Never use a hammer.
#10 ·
@sailerbob Galvanic corrosion of non-alum metals in contact with aluminum is a loaded topic, with variables including 304 vs. 316 stainless, coatings applied to mating surfaces, relative humidity(marine vs. landed), etc. There is no dissimilar metal that does not produce a reaction when mated to aluminum. The restoration of my '85 has discovered so many corroded stock fasteners that I steer toward SS wherever possible except in areas requiring high strength. Generally speaking I would lean toward whatever SJS has come to in the course of developing new-production replacement parts.
