Warm-Start Diagnosis & Fix on my ’87 Esprit Turbo HCi (US, Bosch K-Jet)
Tags
cis kjet
199 views 3 replies 4 participants last post by  HealeyBN7
#1 ·
TL;DR: Chronic hot/warm restart (30–60 min heat-soak) traced to residual pressure bleeding off. Confirmed with a pressure test. Isolated the leak to the primary pressure regulator (not the check valve or frequency valve). Replaced the regulator internals—problem vastly improved.
Symptoms
  • 1987 Esprit Turbo HCi (US) with Bosch K-Jetronic.
  • For both me and the prior owner, warm starts after ~30–60 minutes often required 20–40 seconds of cranking. Sometimes a little throttle seemed to help, but hard to be sure.
  • Only once in two years did it fail to start, and that time the battery was low—likely a second issue overlaying the main one.
  • Practical effect: post-meal restarts = anxiety.
Background / What had already been tried
  • Car owned ~2.5 years.
  • Prior owner installed a rebuilt fuel distributor from SpecialTAuto.com (DeloreanAutoParts.com).
  • Two different Lotus pros had a go at it; one admitted limited K-Jet familiarity. Given what I know now, it's clear that this is a pretty standard k-jet issue and it's clear neither knew how to address k-jet fuel systems.
  • After moving the car to Maui (no local Lotus specialists I know), I decided to learn K-Jet and do it myself. I got to work by ordering a recommended book (link below) and watching a lot of youtube videos on k-jet maintenance. Once I understood the basics, I started chatting with AI.
Quick note on using AI (ChatGPT): It helped me learn quickly and find deep dives, but I had to double-check everything. K-Jet variations across cars can trip you up. Building a mental model of how the system works was essential. You need to understand k-jet well enough to know which variants our cars have (kjet with lambda) and how it's different from other variants.
Mistake #1 — Replacing parts before testing
I initially replaced:
  • Warm-Up Regulator (WUR) with a rebuilt unit (k-jet.biz).
  • Fuel accumulator (upon inspection I noticed mine was leaking).
Neither changed the warm-start behavior.
Lesson: With K-Jet, buy/borrow a proper pressure test kit first and diagnose. Otherwise you’ll waste money and time.
The Key Measurement
With a CTA fuel pressure test kit installed:
  • After shutting off the pumps, system pressure fell to zero within 15–20 seconds.
  • It should hold residual pressure long enough to prevent vapor formation (vapor lock) during hot soak. Mine didn’t.
Working theory: Pressure bled off quickly → hot fuel boiled → pumps had to fight vapor before injectors got liquid fuel → long cranks.
Where can pressure go?
Residual pressure is primarily retained by:
  1. Upstream check valve (at the secondary fuel pump on this car), and
  2. Downstream pressure regulator (in the fuel distributor, returning to tank),
…plus the accumulator helping to hold pressure steady.
So a fast drop usually means:
  • Bad check valve, or
  • Leaky pressure regulator, or
  • Leak between them (e.g., injectors dripping, line/fitting leak, or frequency valve stuck open).
Mistake #2 — Not isolating before replacing
Because it was easier than opening the fuel distributor, I replaced the secondary pump and check valve first. No change—pressure still dumped.
Lesson: Isolate the failure point before buying parts, even if it’s more awkward.
How I Isolated the Leak (simple plugs + caution)
Safety first: Fuel, pressure, and spark are a spicy combo. Work cold, ventilated, fire extinguisher handy, no smoking, eye protection, and keep runtime short when you’re intentionally blocking return lines.
  1. Block the return (briefly!):
    • Removed the double banjo on the distributor return and the small bolt feeding the frequency valve.
    • Plugged both ports on the distributor with DIN 908 drain plugs and copper washers (sizes below).
    • Bumped the pumps ~1 second to build pressure, then shut off.
    • Result: Pressure held → leak was downstream of metering, i.e., pressure regulator/frequency valve area, not the check valve or an upstream leak.
  2. Differentiate PR vs. Frequency Valve:
    • Reconnected the tank return and the frequency valve outlet.
    • Blocked only the frequency valve inlet with an M8 solid bolt (copper washers both sides).
    • Safe to run pumps normally in this configuration (return is open).
    • Result: Pressure still bled off quicklypressure regulator (PR) was the culprit (FV not held open).
This was conclusive: the pressure regulator wasn’t sealing/holding residual pressure.
The Fix
I was hesitant to open the pressure regulator at first, but a local CIS-savvy friend sourced a pressure regulator rebuild kit (o-rings/shims/spring/regulator unit equivalent linked below). We:
  • Pulled the old PR,
  • Installed the new internals with correct o-rings,
  • Re-tested.
After the PR refresh: Residual pressure held. That also implies the frequency valve was fine.
Results Now
  • Warm/hot restarts after full heat soak + ~45 minutes: 2 seconds of cranking and it lights.
  • Not quite “tap-key-and-catch” hot starts yet (which I do have on cold start), but night-and-day better than the 20–40 second cranks.
Tools, Parts & References
Test/Hardware
Part I ultimately needed
  • Pressure regulator rebuild kit (fuel distributor): Primary Pressure Regulator
    (A mechanic friend sourced a similar kit locally for ~US$200.)
Takeaways (so you don’t repeat my mistakes)
  1. Measure first. Get a K-Jet pressure kit and learn to use it.
  2. Prove where the pressure goes before buying parts. Simple block-tests can conclusively isolate the fault.
  3. Respect the system. Short, controlled pump runs when returns are blocked; use proper plugs and new copper washers.
  4. AI can help you learn, but verify details against your exact variant (Esprit HCi uses k-jet with lambda, not ke-jet, not original k-jet).
Happy to answer questions or share additional photos of the test setup/plug locations if helpful.
Special thanks: both Matt West (of west-cam) and GreyGooseRestorations were generous with their time and gave suggestions and helped me double check AI suggestions as I was learning. I really appreciate people who work hard to keep our cars running well, and many of these folks are very generous and helpful.
#3 ·
Good write up, thanks!
And I'll repeat: the CIS-equipped Owners Manual suggests ~ one inch of applied throttle when starting. You need airflow past the metering vane to supply fuel.
