Supposedly the difference in weight between the "lightest form" and the FE is 54 kg or 119 lbs. If the i4 is only 40 lbs lighter than the V6, that accounts for 40 of those 119 pounds, which leaves us with 79 lbs. The 12-way electric adjustable seats probably take up 50 lbs of that 79, which leaves us with 29 lbs. The difference there would be the KEF audio system with its 10 speakers + sub-woofer, and the leather interior, as opposed to the standard audio system and the "performance fabric" cloth seats. The "ultra light weight forged wheels" most likely are lighter than the stock cast wheels so that helps the FE slightly in the weight department.
If you get an i4 and can live without the 12-way seats and the KEF audio, between the engine, seats and audio system, that'll probably save you about 100 lbs (45kg) compared to the FE. You could take the thousands you save by not getting those options, and get a custom paint color. Custom paints are not going to be cheap ($8,500 U.S. from what I've read), so you might wind up spending as much if not slightly more than an FE, but you'll have a car that's 100 lbs lighter, with an engine option that's most likely going to allow for more tuned power, a DCT, and the paint color of your choice.
Now keep in mind any prices we're discussing today are not inflation-adjusted, so 1-3 years down the road the prices are likely to be higher for everything, including the base i4, but you'll have more choices and options then.
