I promised to post the followup on this topic. I got the Evora GT back on Monday after the nearest (though not the selling) dealer handled warranty repairs on the airbag and the driver's window regulator. On the trip over I noticed that the passenger window rattled when partially down, and that is addressed in the shop notes too.
Here is the shop report from this visit, with unimportant and privacy details omitted:
Item "A" is the driver's window regulator. They swapped that out with no issues. I was impressed that the Technician noted a squeak in the seat, but found it interesting that despite having the car an entire extra week they didn't resolve it. They said they'll do so at my next visit in the Spring, which will happen for item "C" below.
Item "B" is the airbag system. During the previous visit the Tech noticed that the harness went from shorted to open as he moved the harness around (which would happen every time the seat was moved forward and back, of course). Unlike other airbag "events" which have been reported here, in this case the wires had actually broken! I suspect Lotus doesn't use high strand count wire here, which would be a good idea since lots of movement is almost a given. I'm thankful the Tech made the airbag harness longer, which should minimize the likelihood of this recurring. Once the harness was reconnected the fault cleared and has stayed cleared. Hooray! Definitely not a fault that would have been fixable with a OBD2 tool, even if we had one that knows the Lotus proprietary codes.
Item "C" is the passenger window rattle. Interesting that the "guides" in question appear to be part of the window glass itself, and not just some standalone clips (as I've seen mentioned here before). They have no idea how long it will take to get a replacement window shipped in from the UK so they're going to get it and sit on it until Spring when the mountain passes clear enough for me to take the car back over to them.
Now we get into the more interesting stuff.
Item "D" originates from the CEL being on when I pulled the car from winter storage last Spring. It showed the traction control system being disabled, and cruise control was inoperative. The CEL cleared itself after a few engine starts but I wanted them to check for stored codes. Odd that the code was for the ambient air temp sensor.
Item "E" was related to item "D" as mentioned. For some reason this revealed a low voltage code stored in the ECU. They asked me if I keep the car on its battery tender: "Yes, virtually all of the time unless we're on an overnight trip. The longest it is ever NOT on the tender is when it's here at the dealership." And it's on the tender 100% of the time it's in winter storage, AND I go check on it periodically to make certain the tender is powered up. Very odd.
Item "F" was an unannounced firmware upgrade to the ECU. Hadn't heard of a "recall" for this and don't know what it is supposed to address. I was a little nervous when I read this because I hadn't noticed anything "wrong" with the drivetrain, but the behavior of the engine hasn't noticeably changed since the reflash.
Item "G" was me having them do a LOF since they were already into the car anyway, and a brake fluid replacement too given the Evora's history of overheating the fluid due to brake line routing. I meant to ask them if they offered a higher-temp brake fluid (so I can minimize how often I need to do this) but forgot in the midst of everything else we were discussing. I may end up doing that myself next time it's needed.
To me, the most interesting parts of this service were the airbag system (I haven't read of others have actual physical harness breakages) and the ECU reflash.
