101 - 120 of 228 Posts
Thanks will look and see which one as there are a few to choose from
edit: they are from a Proton Saga facelift model. Will get part numbers and add.
Though I will say for S1 while the body itself is the jag model but the pinth and mount is custom to lotus. Not sure if same approach on S2
Looks the same with the one on the S2 cars, but at least I should be able to get part numbers for glass, mirror shells etc if they sell these things separately that is. Proton are not overly forthcoming on part numbers, but going to ask s friend in Asia to look for me.
Since there isn't a single place anyone new (or not new) to the Evora sub can go to find parts cross-references, I figured I'd start a thread that will hopefully grow into that definitive source.
To start us off, I'm dumping the stuff I've been keeping track of over the years. If anyone finds something amiss with something posted, please let me know and I can edit. Feel free to contribute a post if you don't see something listed.
A/C Compressor
Toyota/DENSO Part #: 8832042120
UAC Part #: UAC CO 10856C (FROM A USA TOYOTA RAV 4 3.5L V6 2006-2012)
A/C Dryer/Receiver
PACCAR Genuine Parts
1711509PAC (for a Peterbuilt)
1400604PAC (cross-ref)
Alternator
Toyota 27060-31082
Denso 104210-2071
ARB Lube
Super Lube (PTFE)
AquaShield (green snot)
Battery Alternatives
AutoZone T6-DLG (DuraLast Gold)
Interstate MTP-91 (Group 91)
Duracell SLI48AGM (Group 48)
Serpentine Belts
Gates K070822 - NA
Gates K071130 - S
Without AC Compressor (NA) - 7PK-1988
Belt Tensioner
Toyota 16620-31040
Idler pulleys
2x No2 idler pulleys (Toyota 16604-31020)
2x Idler cover plates (Toyota 16649-31020)
Brake banjo crush washer
Pegasys Racing 3241-3/8
Brake Pad (Front)
EBC Redstuff DP3036C
Ferodo DS2500 - FRP3083H
Brake Pad (Rear)
EBC Redstuff DP3060C
Ferodo DS2500 - FRP3115H
Brake Switch
GM/Saab 51 06 141
SLS334 Stop Light Switch
CHMSL
Perei HS25
MG Rover XFG000150 (clear lens)
MG Rover XFG000140 (red lens)
CHMSL Connector
BMW 61-13-8-373-583
Clutch Slave Cylinder
Toyota 31470-12190 (Avensis, Verso, Corolla Verso, RAV4 Diesel)
Aisin CRT-087 (Toyota Avensis)
Valeo 804777
Coolant Cap
Toyota 16475-28140
Door Hinges
Ford Focus (?-1998-?)
Headlight Washer Pump
Bilstein Febi 26274
Headlight Washer Nozzle Cylinder
Mercedes-Benz W163 1998-2005 (transfer OE spray heads)
Thermostat
Toyota 90916-A3003
Thermostat gasket
Toyota 16325-62010
Crankshaft Position Sensor
Toyota 90919-05060
Dome Light
VAUXHALL ASTRA/GM/Chevy Spark 13126729
HID ballast
03-05 Audi A4 / S4 89030471
OEM Valeo LAD5GL 89035113
Mass Air Flow
Toyota part # 22204-31020
Denso part # 197-6110
O2 Sensors
Bosch 0258006127
Bosch MHK 100840
Lotus A117E6007F
Denso DOX-2017
Rover MHK 1008 40L
Bosch 0 258 006 915 (Universal)
Oil Filter
TRD PTR43-00082
Toyota 04152-YZZA1
K&N PS-7020
Mobil 1 M1C-251
Wix 57047XP
Wix 57047
Parking Brake Shoes
Peugeot 406 (8B),406 Break (8E/F), 406 Coupe (8C), 607 (9D,9U) =>1995-2005 - LPR 08400
Diameter (mm): 185
Width (mm): 30
Power Steering Pump
Toyota 44310-07040 W-23
Spark Plugs
Denso FK20HR11 (NA)
Toyota 90919-01247 (NA)
Starter Motor Brushes/Yoke (NA & S Manual Transmissions)
Hitachi S114-945
Supposedly S114-943 brushes fit
REMIUM BRUSH ASSEMBLY-NISSANS & INFINITY WITH HITACHI STARTERS
For : • Hitachi PMGR Starters
Also See: 68-8129;68-8137;69-8118
Used On: BMW (2001-2006) , Infiniti (1996-2001) , John Deere (1998-2005) , Kubota (1999-2010) , Nissan (1995-2010) , Yanmar (1994-2003)
Replaces: Hitachi 2114-73105, GD213648-D, Nissan, Infiniti 23378-0M300
Unit Nos: BMW 12-41-1-354-823, 12-41-1-740-373, 12-41-1-740-374, 12-41-1-740-375, 12-41-1-740-379, 12-41-7-515-391, 12-41-7-515-396; Bosch 0 001 108 401; Denso Europe DSN954, DSN955; GM 10455018; Hitachi S114-800, S114-800A, S114-800B, S114-801A, S114-801B, S114-801C, S114-801CR, S114-801D, S114-801E, S114-802A, S114-802B, S114-802BR, S114-806, S114-806A, S114-806AR, S114-815, S114-815A, S114-817, S114-817A, S114-821, S114-821A, S114-822, S114-822A, S114-822B, S114-833B, S114-844, S114-844R, S114-902, S114-902A, S114-902B, S114-902R, S114-922; Hyundai 36100-2Y000; John Deere AM879072; Kubota T1060-16800, T1060-16804; Letrika (Iskra) 11.139.430; Letrika (Iskra) Sales IS 9308; Letrika (Iskra) Tech. AZE2198; Nissan, Infiniti 23300-0M200, 23300-0M200R, 23300-0M201, 23300-0M300, 23300-0M301, 23300-0M302, 23300-2J260, 23300-2J261, 23300-2J261R, 23300-2J262, 23300-2Y900, 23300-2Y900R, 23300-31U00, 23300-31U01, 23300-31U01R, 23300-31U02, 23300-31U02R, 23300-63J02R, 23300-8H00R, 23300-8H300, 23300-EN200, 23300-EN200R, 23300-EN20A, 23300-EN20B, 23300-EN21ARE; Prestolite 20513073, 20513073; Renault 7701065384; Valeo TM000A24601; Valeo Tech 579377; Yanmar 118400-77010, 129608-77010, 129698-77010
Lester Nos: 17146, 17695, 17702, 17713, 17745, 17779, 17980, 17982, 18219, 18288, 18290, 18440, 32265, 6330-HISteering Wheel Slip Ring:Ford 2M51-14A664-DE
2002-2005 Focus
Starter Motor Brushes/Yoke (NA & S IPS Transmissions)
Complete Starter: Toyota P/N 28100-20021, Denso 428000-1841
Brush Holders/Yokes:
Denso: 228000-9900, 228000-9901, 228000-9902, 428000-1080, 428000-1081, 428000-1840, 428000-1841, 428000-4310, 428000-4311, 428000-5870, 428000-5880, 428000-5903, 428000-5904, 428000-5913, 428000-5980, 428000-5981, 428000-5983, 428000-7492, 438000-0630,
GM: 88975515
Lexus: 28100-0A010, 28100-0A010-84, 28100-0A011, 28100-0A011-84, 28100-0P031, 28100-0P032, 28100-0P080, 28100-0P080-84, 28100-20020, 28100-20020-84, 28100-20021, 28100-20022, 28100-28040, 28100-28041, 28100-28041-84, 28100-31100, 28100-31101, 28100-31102, 28100-36120
Scion: 28100-20020, 28100-20020-84, 28100-20021, 28100-20022, 28100-28040, 28100-28041, 28100-28041-84, 28100-31102, 28100-36120
Toyota: 28100-0A010, 28100-0A010-84, 28100-0A011, 28100-0A011-84, 28100-0H090, 28100-0H091, 28100-0H091-84, 28100-0V010, 28100-0V011, 28100-0V012, 28100-20020, 28100-20020-84, 28100-20021, 28100-20022, 28100-28040, 28100-28041, 28100-28041-84, 28100-28060, 28100-28070, 28100-28071, 28100-28072
Tail Light Connectors
TE Connectivity AMP
Econoseal III 070
344265-1 (male 6-pin)
345259-1 (female 6-pin)
TPMS Valves
Autel MX 433 - Needs Autel programmer
Schrader 20159 or 13227143
Also fits:
Elise 2008+
Exige 2008+
SAAB 9.3 07/2002 -- 04/2005
SAAB 9.5 07/2002 -- 12/2008
Window Regulator Cable
1.6mm (or 1/16") - 31 3/4" length
Home Depot ferrule & stop set
Wiper Blade
Bosch Aerotwin AM26U (OEM)
Bosch Aerotwin AP26U (symetrical)
Valeo 900266B Frameless ULTIMATE 26" All-Season
Wiper Motor
Guts from 1995 VW Golf (Bosch)
Windshield washer spray nozzle
Ford Focus MK4 2011+ heated front washer jet (mist type) - 1708797
Front and Rear fuse panel fuses
MTA MiniVal (standard profile)
MTA MaxiVal
the wiper motor on the 2017 isn't the guts from 1995 VW Golf (Bosch) My mechanic tried that. Maybe its different in earlier generation cars.
Discussion starter · #106 ·
Yeah, I think even on the S1s it's slightly different. I also tried the VW Golf part recently on mine, but the armature was too short. I'll update the list and remove that reference.
Anyone have a number for the OEM rotors? Sorry if I missed it.
If you mean part number you can easily look it up lotustarts.com enter your model, year and all other required info and go to the proper section. It's pretty intuitive.
owns 2006 Lotus Elise
Yes, I didn't know if there was a cross-reference #.
Reactions: Catsailr27
DBA's are aftermarket. Not sure who made the OE's might have been AP Racing. If you are looking for Rotors the GRP and Inokinetic sell them
Got it thank you. I'll likely go Inokinetic; I've been a long time fan of Shinoo and S111. Also looks like they have a pretty good deal going on a package currently.
You have to start with the OEM part number to cross reference it.
I think maybe he meant a cross-reference, not just the OEM part number. A cross-reference would be another vehicle that uses the exact same part, though the number would be different. For example, my '91 Elan needed a fuel pressure regulator. Finding it cross-referenced as being the same one on a Corvette of the same year group (but the Corvette had two of them) made getting the part a breeze. Parts suppliers tend to look for parts based on year/make/model/variant, so these cross-references are incredibly helpful.
Discussion starter · #118 ·
AP Racing is the OEM for the Evora rotors and calipers, but IIRC, they're not used on any other vehicle, and AP doesn't sell them directly, so if you want the OEM ones, you have to get them from Lotus.
So the REAL question on brake rotors is: Does anybody know another vehicle that uses the same rotors, or rotors with the same dimensions? On the plethora of suppliers' websites that do not have Lotus as a choice when entering the vehicle, what other vehicle can be used to find the right rotors? For example, the 1991 Elan M100 I used to own used the same rear rotors as the 1991 Chevy Lumina. With that information, one could go to any parts supplier and get rotors.
Regarding serpentine belt on 2011-2014 Evora Supercharged:
The factory B132E6500H belt I just received is a 7PK2846 (Toyota/Bando 90916-02700, which I can't find listed anywhere).. the Gates K071130 that MWR/people have been suggesting is a 7PK2871. That's 2.5 centimeters longer than the factory belt. Seems like a lot to ask of the tensioner to take up as the belt heats up, ages and stretches.
Seeing as how Lotus is only charging $45 for this belt retail now, and that Gates is $29 on rockauto plus shipping... conclusion seems pretty obvious.
Also for anyone who doesn't know, the 400/410/GT belt C132E6533F is a gatorback style belt that Lotus is adamant we put on people's cars here. Cost is an even more reasonable $38. (it's a 7PK2958 for the curious)
Incidentally, the Lotus Belt B132E6500H is now $98. How's THAT for inflation.
