141 - 160 of 228 Posts
for which years? I just spent WAY too much on oem sensors and stems for a 2021 gt lol
I can only confirm the 20159 and now 29204 work on my 2011 S. I do not know if the TPMS system changed/evolved in the 400/GT.
Strangely, the Evora 400/GT oem part is a different number than the Evora/S. BUT, both parts cross over to a ton of Eliges that are listed as working with both sensors. I'd be surprised if the Schrader sensor didn't work in the 400/GT but maybe someone here can confirm they have used the Schrader sensors in a newer car to be sure.
On my GT - they changed to 434hz rather than 433hz, if I recall.
Just found that the Evora 400/GT Daytime Running Lights (DRL) module is Nolden (NCC) NSV-022. Used on a few other cars & fairly readily available on your favorite auction site used for about $60.
Much better than having to buy the module plus 2 lights as a kit from Lotus (A132M0284F) for a mere $591
My database sez:
Description Manufacturer Part_number Lotus_Part_Number Comments Source
Mirrors, Side Proton From a Proton Saga, late model, like 2020 Biggrif
Mirrors, Side mirror assembly, including housing, glass, and covers 2001-2009 Jaguar X-Type, several part numbers West-of-Hethel
My database sez:
Nah, those Jags don't have the integrated signal like the GTs do.
Well, that's all I have. If you find what it came off of, let us all know and I'll add it to my database.
At least with the S1s the mirror housing might be the jag but how it mounts is bespoke to lotus. So depending on what you're trying to do may not get far.
Discussion starter · #156 ·
Is there any new reference no. For the wiper motor?
Not that I'm aware of. You might reach out to Chris @ B is for Build on YouTube, as he did successfully find a replacement motor during his rebuild, but couldn't remember the surrounding specifics.
Has anyone found alternative parts for the exhaust hangers A132S0171F? To me they look like 1” or 25mm anti roll bar bushes (sway bar bushes). Toyota Hiace part looks very similar but the rubber bushes may not take the heat as well as a poly bush. Lotus prices ridiculous!
