If you want to make sure that the VIN isn't lost in any of the Lotus ECUs, wait 30 minutes after the engine has been turned off to disconnect the battery. The VIN is compromised in the event that a power source is removed before the ECU is shut down. It has to do with the VIN being written back into ROM from RAM...
In my tunes, I have disabled this issue and force the ECU to power down after shut-off. The lotus VIN bug is an unintended consequence of the heat soak algorithm in the ECU...
Nevertheless, VIN retention is a "problem" on all the Toyota T4 and T4E ECUs when it comes to low or no power at inopportune times. Bottom line, wait 30 minutes to pull the battery after the car is off. This will ensure the ECU is powered down... You can also zap the VIN by trying to start the car on a too low of battery with the "click click click"... Not always but some times...
Normally, the white dash cars don't care about a lost VIN. The black dash cars care a lot, so be particularly careful with those....
edit: On the black dash cars, they can actually go into limp with a lost VIN. That said, on any black dash ECUs I tune, I disable that feature knowing that the likelihood of losing the VIN is relatively high...
-Phil
