Temp is reading Celcius
4 reading
2.8K views 7 replies 6 participants last post by  shay2nak
#1 ·
I have an 08 Exige (fed car). The coolant temp gauge is reading in Celsius. Anyone know how to change it back to Fahrenheit?
#5 ·
Car was purchased new from Newport European located in Southern California I'm certain it is a fed car since the ecu has Fed written on it and it originally displayed in Fahrenheit. The Display just recently changed to Celsius after charging the battery. I also noticed that some tell tale lights have changed as well. Instead of BRAKE it now shows a red exclamation mark when it is engaged.
#6 ·
The cluster is programmed based on VIN definition, there have had some cases where as a result of the battery going flat the pack looses its memory and needs to have the correct VIN re-entered, this will need to be done by a Lotus Dealer using Tech Centre. Also ask the dealer to check the instrument pack software level as per Service Bulletin 2008/12.
Michael
#7 ·
I thought there was an easy way to reprogram that back & forth.....:shrug:
